G35 & G37, Coupes & Sedans
Rear rotors all rusted
Old Feb 27, 2012 | 06:53 PM
  #46
VMRWheels's Avatar
Looks much nicer!
Old Feb 27, 2012 | 06:54 PM
  #47
Frankieg35's Avatar
Yeah just prep them like u did the rotors and paint them.. if your keeping them on the car then get the brush on paint.. its less messy.. lol
  #48
denny19's Avatar
thanks VMR!
Old Feb 27, 2012 | 06:55 PM
  #49
denny19's Avatar
do you still apply multiple coats with the brush on or just 1 coat?
  #50
broke_as_ajoke's Avatar
bro.. just paint.. it aint hard..tape everything u don't want paint on.. Have u ever changed brakes before.. if so u know the caliper has to come off the rotor. Just tape up the inside of it so u don't get paint on the piston.
Old Feb 27, 2012 | 06:58 PM
  #51
denny19's Avatar
no I never changed brakes before...thats why Im asking
  #52
denny19's Avatar
and I dont plan on taking the Caliper off the car because Im not too familiar with how to do that
Old Feb 27, 2012 | 07:01 PM
  #53
well, in that case they sell a brush on paint.. You might want to follow the same steps u did before.. tape everything up (rotor) >>> then prime or use a high temperature paint and BAM!! u are done..
Old Feb 27, 2012 | 07:02 PM
  #54
Frankieg35's Avatar
Just clean the caliper very good, put one coat on and let it dry then apply 1 or 2 more coats, letting it dry in between each coat.. they sell a brush on caliper paint..
Old Feb 27, 2012 | 09:28 PM
  #55
TORETTO's Avatar
just get these and you don't have to look at the rust any more
Old Feb 29, 2012 | 03:08 PM
  #56
Canadiotica's Avatar
Great job jumping in and painting them. Turned out well.
Old Feb 29, 2012 | 07:06 PM
  #57
NjMatteSedan's Avatar
get the duplicolor brush on paint as Frankie said. it's a little more expensive (around 15$) but the end result will be worth it because they come out a high gloss black when it's dry. just spray them with the brake cleaner it comes with and do about 3 coats . You should see if you can paint the top part of the rotors too the edges are rusted
Old Feb 26, 2014 | 12:18 PM
  #58
sylar0810's Avatar
Rust on outer edge of rotor
Originally Posted by marshallpre1
Take your car out for a spin and after using the brakes a few times... poof rust is gone. It's just surface rust....
Hey I know this is an old thread...and sorry I'm not that familiar with cars as well...is it normal to have rust on the rotor about half an inch from the edge? This is only happening on one of my rotors, for the other 3, the brakes seem to be making contact all the way to the edge. Do I need to adjust my calipers? New break pads?
Old Feb 26, 2014 | 12:32 PM
  #59
Mustang5L5's Avatar
Looks like the outer edge of the pad isn't contacting for some reason.
I'd pull the wheel off and unbolt the caliper and inspect the pad.
These cars are notorious for the rear slide pins seizing, causing abnormal brake wear and soft pedals
Old Feb 26, 2014 | 08:36 PM
  #60
Frankieg35's Avatar
Damn, thats strange.. Definitely get that looked at soon..
