G35 & G37, Coupes & Sedans
Excessive road noise?
Old Dec 20, 2013 | 07:36 PM
Urbanengineer's Avatar
Meier, what set of tires do you have on your coupe? Low quality tires are the biggest causation of road noise.
Edit: Yeah...
Old Dec 21, 2013 | 06:01 PM
Mustang5L5's Avatar
I agree with tires being main cause. Also, check to make sure your wheel bearings aren't failing as those contribute to road noise as well.
My '06 sedan is quiet on the highway. Only time it got loud was when my wheel bearings were failing, and my exhaust miffler flange rotted out.
Old Dec 26, 2013 | 04:03 PM
infinitidude's Avatar
If you have so much noise that you have to turn your volume to 25 kinda tells me it is not the tires, especially if it sounds like it is from the rear of the vehicle. I would definitely say lean more towards wheel bearing issues which is common with G's.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
alinero718
Sep 27, 2015 09:35 PM
