G35 & G37, Coupes & Sedans
HELP!!! Car Won't Start!!
Old Mar 15, 2012 | 02:30 PM
jrhykushi's Avatar
http://www.youtube.com/watch?feature...&v=AooYN5KYJ0M
can anyone diagnose my car with anything? i replaced my battery about 2 weeks ago, and just 2-3 days ago, my car won't start. all the electrics in the car work, but my engine won't turn over. when i try to start the car, there is only a single click (at 0:08). ignition problem?
thanks in advance
p.s. the car is an '06 coupe
Old Mar 15, 2012 | 04:50 PM
TORETTO's Avatar
Make sure the terminals are connected tightly.
Old Mar 15, 2012 | 04:59 PM
JaE35's Avatar
Moderator
G35 Sedan
Time for a new starter
Old Mar 15, 2012 | 07:30 PM
jrhykushi's Avatar
Any websites you would recommend I purchase from? or should I just go straight to the dealership?
Old Mar 15, 2012 | 07:40 PM
JaE35's Avatar
Moderator
G35 Sedan
i wouldn't buy a starter from the dealership...pull yours out and take it to autozone or somewhere nearby. they can hook it up to a machine and verify its out. From there they can give you a replacement and credit for your old one
Old Mar 15, 2012 | 09:00 PM
TORETTO's Avatar
PM this one dude named JaE35. He can get you a 80% discount anywhere.
Old Mar 20, 2012 | 12:12 PM
jrhykushi's Avatar
Some people are telling me it's a starter problem, and some are saying it's the starter relay. For the relay, the dealership said I would need to purchase the whole IPDM, which will run me about $600. A starter from the dealership is $340. Yikes!
I'll bring take out the starter and bring it over to Autozone for a diagnosis tomorrow. Does anyone know if this is a difficult job? Thanks guys!!
Old Mar 20, 2012 | 12:29 PM
slim17265's Avatar
you give no info. when turning key do you get a click...or...a buzz...? if not look at your battery terminals FIRST. many time a green slime builds up inside and around the male terminal creating NO contact...clean this with wire brush first.. then check battery for bad cell.
Old Mar 21, 2012 | 05:33 AM
jrhykushi's Avatar
I get a click. All my electrics still work fine, so I don't know if it's a battery terminal.
Old Mar 21, 2012 | 04:58 PM
saywat?'s Avatar
are the starters bangable on the g35?. i used to do in on my old 240 when the starter was going bad.
Mitsuko's Avatar
i can't see the video so don't know if you tried, but definitely try jumping it first still. i had a new battery but had a short somewhere draining it... there would still be enough juice to power all the electronics, but it wouldn't crank at all. if it still doesn't start, then i agree with checking the starter coil
Old Mar 28, 2012 | 07:57 PM
jrhykushi's Avatar
Does anyone have instructions or a DIY for how to replace the starter on an 2006 coupe 5AT? I went under the car and found it, but there seems to be a metal frame thats in the way
chinee
Jun 10, 2024 07:48 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
newg37
Jul 26, 2015 09:32 AM
kenthung
Jul 21, 2015 05:56 AM
