G35 & G37, Coupes & Sedans
  #796
Old 05-27-2013, 01:03 AM
StL Stranger's Avatar
installed the Metra kit and Kenwood DDX770
  #797
Old 05-27-2013, 05:46 PM
Stubie1918's Avatar
Looks good
  #798
Old 05-27-2013, 10:26 PM
TrippleGs's Avatar
Added Plenum spacer, and Injen Cold air intake. Cant decide which Cat sets to put on first. What would you do?
INVIDIA 60MM TESTPIPE HIGH FLOW CATs
Kinetix Racing G35 High Flow SMOG Legal Cats
which will go along with, but as soon as it is delivered
MEGAN 3" Stainless Dual Tips OE RS Catback Exhaust
Cant decide... Should i keep the test pipes? Not planning on racing my car. should i really put them on, and then put the others on just for inspection time? Is it really worth it?
  #799
Old 05-27-2013, 11:43 PM
TougeMonsterG35's Avatar
Fyi no high flow cats are carb legal.... I went with Crawford hfc and I love em..... Remember u get what u pay for.
  #800
Old 05-28-2013, 01:00 AM
butkiss1's Avatar
<a href=http://s788.photobucket.com/albums/yy170/butkiss1/?action=view&current=2013-05-24201004_zps735ac4c1.jpg target=_blank><img src=http://i788.photobucket.com/albums/yy170/butkiss1/2013-05-24201004_zps735ac4c1.jpg border=0 alt=></a>
Brand new pair!
  #801
Old 05-28-2013, 07:36 AM
TrippleGs's Avatar
The Indivia cats seemed to be rated better. But the kinetix are suppose to be quieter. Not really going for a very loud sound. The lower the better
  #802
Old 05-28-2013, 07:48 AM
LoSt180's Avatar
Discovered Nissan still likes to use goo filled bushings.... Think I found the cause of vibration at high speed...
Whiteline bushings and a Nismo diff cover on order from CZP.
  #803
Old 05-28-2013, 09:48 AM
TrippleGs's Avatar
Says right here that these do pass inspections.
http://www.conceptzperformance.com/Cart/description.php?II=2981&Car_Type=G37&UID=201305280 64134174.254.114.235
  #804
Old 05-28-2013, 09:55 AM
TORETTO's Avatar
Received 1,939 Likes on 1,249 Posts
That page you just linked even said that those do not have CARB numbers. So while it might pass the sniffer, if the smog tech actually decides to check under and question them, and you have no CARB number, you're **** out of luck.
  #805
Old 05-28-2013, 10:11 AM
TrippleGs's Avatar
How would one get around this?
  #806
Old 05-28-2013, 10:12 AM
TORETTO's Avatar
find a smog tech that doesn't give a ****.
  #807
Old 05-28-2013, 11:45 AM
CORONAG35's Avatar
I know its not one of ur options but u should get ART pipes good sound no rasp and increase in hp up with a tune. . . .
  #808
Old 05-28-2013, 01:13 PM
Peoria35sedan's Avatar
If he's worried about passing a smog test why should he but ART pipes? Also, they are LOUD, again not what he is looking for. I would just call CZP and see what options they have, I know they have Stillen and a few other brands but none of them are CARB legal so if you're in CA you'll need to find away around the inspection.
I changed my oil and installed new brakes over the weekend, ebay x drilled and slotted rotors have close to 60,000 miles and no problem having them turned, I'll order another set just in case.
  #809
Old 05-28-2013, 01:15 PM
JaE35's Avatar
Moderator
G35 Sedan
picking up stock exhaust parts..think the days with the 04 are numbered
  #810
Old 05-28-2013, 02:26 PM
CORONAG35's Avatar
Peoria35sedan, theyre not loud they just give a deeper note to the vq sound, and if he is worried about passing smog, then he shouldn't take his cats off or just pay a lil extra for a shop to pass it. I was just giving him another option than the ones he was thinking of
Quick Reply: What did you do to the G today?
