AUTO SEATS to PULL BAR ADJUST
I did search and nothing ,
Im worried about my seat motors going out, I can tell already that its not performing that well when adjusting. So im leaving them on lowest setting adjustment. IS there a seat rack that has the pull bar to adjust going forward and backwards ? Wish i didnt have the power seat functions, it takes so long for passengers to get in and out while in the rain
I wantto keep my oem seats , or get 350z cloth seats
any info would help thanks !
I wantto keep my oem seats , or get 350z cloth seats any info would help thanks !
For a slider mechanism you'll. need to use another seat with aftermarket brackets, custom fab a base for your oem seats, or use a 350z seat- I think the driver side should bolt in painlessly
COULDNT I JUST buy an aftermarket rail system that they sell for the G35 and bolt it up to the OEM seats?
such as this
http://www.frsport.com/Bride-N108MO-...e_p_26804.html
such as this
Not without cutting and welding the existing base over. The oem seat has a chunky integrated bottom end, also depending on your year other functions such as recline are also motorized and would be lost in the process. Disconnect you battery and pull your seat out if you'd like to see what you're working with.
luckily the top portion for the back support has a pull bar adjust and not motorized. But thankyou for your knowledge, ill just do that and see how i might go about this.
