Shifter issues
Shifter issues
Having issues with shifting out of Park. The shift button will pop in and out when i am in R-N-D-DS-M, but when it is in Park it will get stuck. When the car is off the Shift into Park light and notification will go off. Here is a video.
There's a safety switch between the brake pedal and the shifter. Not sure how its wired up but you should check it out.
I had same issue 8 years ago with my Grand Prix. I had to manually push the shift release button everytime to shift.
some thing happened to me in my 04 g35x, i had popped the fuse while wiring the brake light on a new spoiler. the fuse was in the driver side kick panel. if that fuse is gone when to apply the brakes your rear brake light should not illuminate also you would not hear the 'click' from the shift lock disengaging
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
newbdriver01
Jul 15, 2015 06:10 PM
