G35 & G37, Coupes & Sedans
Official Repair Cost Thread?
Old Jun 5, 2013 | 11:41 PM
Kyle Barbaro's Avatar
This may or may not be a good idea, but I thought it might be cool to maybe list the following to give people a better general idea of how much there looking at to fix a specific problem. If you got something done or repaired recently post them up?
Example.
Year: 2005
Body: Coupe
Repair: Rattling Heatshield
Price: $13,000
Dealership or Private: Stealership
Old Jun 5, 2013 | 11:48 PM
ItsA..Gthing's Avatar
Im sure prices would vary...
Replacing drive belts on my 03 G35 coupe...$45 parts and $55 for labor..$100 total..My mechanic
Old Jun 6, 2013 | 12:05 AM
rsingerG35's Avatar
Example.
Year: 2005
Body: Coupe
Price: $13,000
You paid 13,000 to fix a rattling heatshield?
Year: 2006
Body: Coupe
Repair: Passenger power window broken
Price: ~$600 for motor and regulator.
At the local stealership.
Old Jun 6, 2013 | 12:09 AM
Yes, in pennies. HOLY **** 600 FOR THE MOTOR AND REGULATOR?!
Old Jun 6, 2013 | 12:23 AM
rsingerG35's Avatar
Would have been more. But military discount was applied.
Old Jun 7, 2013 | 11:14 AM
MUMM RA's Avatar
Last year I decided to remove my door molding and my passenger side left an ugly shadow mark which cost me a little over $900 to get the whole side of my car painted.
This year someone backed into me and their tow hitch just dented my front bumper. Might be time to upgrade to the nismo front.
Year: 2005
Body: Coupe
Repair: Front bumper fix
Price: $ 600 (Unless I upgrade to the Nismo)
Dealership or Private: Amsley's in Chambersburg, PA
Old Jun 7, 2013 | 12:31 PM
Upgrade^^^
Old Jul 20, 2013 | 08:10 PM
I have a leak in my brake fluid somewhere, every few weeks my lights come on, and its because of the brake fluid..how much do you guys think it would be? I know it could be a few things, but id like to get an estimate on what would seem fair
Old Jul 21, 2013 | 02:58 PM
telcoman's Avatar
Veteran: Army
If I were you I would get that checked out ASAP.
If you needed to slam on your brakes to possibly avoid an accident and the brake pedal suddenly went to the floor and you injured or killed someone the cost to you could be far higher than just the brake repair.
Just my $.02
Telcoman
Old Jul 21, 2013 | 03:39 PM
Just my $.02
Telcoman
its a slow leak, i plan on getting it checked this week, any ideas on a price?
Old Jul 21, 2013 | 04:30 PM
livinglegend's Avatar
I like the idea behind this thread, but I dont see it being overall very useful or effective. The problem is there is no "standard" cost to fix anything. anywhere. Even on the local level, many shops charge vastly different labor rates. Each parts supplier puts a different price on all of their parts. And a lot of people either do the work themselves, take the vehicle to a friend or local private shop, go to the dealership, ignore the problem all together. There really is no way to accurately gauge a repair cost to that basic of a level. Now multiply that across the continent and its ridiculous.
The same job might cost $300 dollars here in minnesota, and then $600 or $700 dollars in say, Hawaii due to parts availability alone. Then between those two quotes alone there coule be hundreds of dollars differing form the dealership to a private mechanic. Another thing is the specifics of the problem. You cant ask "how much will it cost to fix the leak in my brakes?" unless you know what the problem actually is. It could be a $5 piece of brake line thats leaking, or you could be replacing the caliper or an ABS module. No way to tell unless you take if to a shop and have the problem evaluated. A lot of shops will just "look" at it for free to diagnose the problem but its expected that you have the problem fixed there should you so choose. Dont be a douche and have them diagnose it then take it to a different shop because theyre $50 cheaper.
If you need a quote about getting something fixed then just call the shop. Plain and simple. The shop can determine the price based on flat rate, special tools needed, parts cost and availability, etc. Do the work and call around to you local shops and get quotes. Then go for the cheapest one, or the one you feel safest going to, or do the work yourself. Nobody on here can tell you what you are going to pay at a different shop. They can give you a vague ballpark figure and thats it. There can always be underlying problems and hang-ups that turn a simple "$200" job into $400 in a new york minute.
Old Jul 21, 2013 | 04:54 PM
telcoman's Avatar
Veteran: Army
You are correct.
Labor rates vary widely across this country. Here in NJ the dealer labor rate is $130.00 per hour
There are independent shops charging $80 or $90 an hour.
Would I trust them to check out leaking brake fluid on my G37
Hell no!
I would however insist on seeing where the leak is coming from when on a lift at the dealer. Probably a leaking caliper or a leak in the brake lines. Also could be the master cylinder since the op didn't mention any pulling to one side when applying the brakes.
I have a good relationship at my Infiniti dealer and no longer trust any independent shops to touch my vehicles due to bad past experiences. Infiniti dealer workmanship is excellent and they are **** about getting an excellent survey whenever any work is performed.
The cost is a little higher but I've been a very happy Infiniti owner since December 2005
As to the op budget $1000.00 and if it comes out less than that go celebrate with a few beers
http://www.youfixcars.com/disc-brake-caliper.html
cheers
Telcoman
5ATSEDAN
Oct 12, 2015 07:55 PM
Eomfd
Aug 29, 2015 12:42 AM
derres
Aug 28, 2015 03:27 PM
mostestG35
13
Aug 15, 2015 05:56 PM
Team STILLEN
Aug 10, 2015 08:17 PM
