G35 & G37, Coupes & Sedans
Camshaft Position Sensors
Old May 24, 2015 | 02:19 PM
bchalks's Avatar
I replaced both camshaft sensors, reset ECU, drove 10 miles but the CEL came back on.
I got the sensors off Amazon and they came in genuine Nissan/Infiniti boxes.
Any idea what this means? Faulty new sensors? Bad install? Anything I should double check?
Old May 24, 2015 | 02:30 PM
crl's Avatar
crl
What procedure did you use to reset the ECU?
Old May 24, 2015 | 02:43 PM
bchalks's Avatar
the accelerator pedal press method. Do you think removing the negative terminal of the battery is a better way to do it?
Old May 24, 2015 | 05:40 PM
Urbanengineer's Avatar
Yeah because it is easy.
Old May 24, 2015 | 06:23 PM
bchalks's Avatar
I'll try it. I'm also going to check the bolts to make sure they're tight and didn't loosen themselves while I was driving
Does anyone have any other suggestions?
Old May 25, 2015 | 09:25 PM
bchalks's Avatar
Bump.
Any suggestions? Going to take the sensors out and check that they are working but if someone has a simpler solution I'd love to hear it
Old May 26, 2015 | 09:22 AM
Duriisimo's Avatar
Did you see what code(s) is showing when the CEL came back on?
Old May 26, 2015 | 01:14 PM
Mustang5L5's Avatar
What code is showing?
Old May 26, 2015 | 02:55 PM
bchalks's Avatar
P0011 and P0021 were the original codes.
Going to re-check the codes in a bit and see if the same ones are being shown
Old May 26, 2015 | 03:06 PM
Mustang5L5's Avatar
Page 141
http://www.nicoclub.com/FSM/G35/Coupe/2004/ec.pdf
I'm not sure an ECU reset really erases engine codes. I could be wrong. I'd erase the codes via a scanner and see if they come back. If so, i'd do some troubleshooting via the FSM
Old May 26, 2015 | 05:19 PM
bchalks's Avatar
Erased the codes at Oreillys today. No luck.
Going to read over the FSM tonight
Old May 26, 2015 | 09:33 PM
saywat?'s Avatar
code readers are so cheap now days theres really no reason to not have one. I got mine from amazon was only like $10-20 . reset/scan codes with a push of a button. I used to do the pedal dance but got tired of it lol
Old May 26, 2015 | 09:58 PM
Almightyone's Avatar
Do a search. Look for "Cause for dreaded p0011/p0021 codes everyone is looking for" I think that is the name of the title. It says in that thread that it isn't a sensor issue. I believe it's an oil pressure issue.
Old May 26, 2015 | 10:47 PM
bchalks's Avatar
I checked out that thread and it looks like I have my work cut out for me
Thankyou for your help, Almightyone
Old May 26, 2015 | 11:01 PM
No problem. Hope it helps.
