G35 & G37, Coupes & Sedans
LOLmustangLOL's build (Progress still to be made)
Old Jan 3, 2017 | 03:49 AM
  #166
saywat?'s Avatar
Hmm idk it jus looks higher than the wing I'm familiar with
Old Jan 3, 2017 | 03:54 AM
  #167
LOLmustangLOL's Avatar
Maybe it's the stock sport spoiler without the CF in it? This is the black edition one, sits a bit higher.
Old Jan 3, 2017 | 03:59 AM
  #168
saywat?'s Avatar
Oh I see.
*looks like reflection or is mounting part that wide?
Old Jan 3, 2017 | 04:08 AM
  #169
yep it's a pretty wide point but it comes back in
Old Jan 3, 2017 | 06:52 AM
  #170
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by LOLmustangLOL
since the GTR was based similarly off the G35.
I'm going to need definitive, verifiable proof in print that validates this statement before I can even begin to believe it's true. Personally I think you've lost your mind.......
If you are making an assumption based on how the rear ends look, then you're doing it wrong.
Old Jan 3, 2017 | 07:11 AM
  #171
Blue Dream's Avatar
After a quick internet search I can find nothing to support your claim so I call The following quote was lifted straight from Wiki, no mention of a G35 design anywhere.
C'mon man, these kinda brainfarts are embarrassing so please be careful what you say on here. False claims get called out pretty damn quick. This isn't our first rodeo for a
lot of the old timers here.........
Design
A rear view of the GT-R, showing the signature taillights known since 1972 on the Skyline c110
Nissan chief creative officer, Shirō Nakamura, has likened the new GT-R to the giant robots of the Gundam series.[13] Nakamura stated: "The GT-R is unique because it is not simply a copy of a European-designed Sports car; it had to really reflect Japanese culture."
Nissan's American designers sculpted the rear three quarters of the vehicle, while their European designers sculpted the roofline.[13]
Polyphony Digital, creators of the Gran Turismo series of motor racing video games, were themselves involved in the development of the GT-R, having been contracted to design the GT-R's multifunction display.[14]
The customizable multifunction display integrated into the dash of the GT-R
2014 Nissan GT-R interior
Nissan PM platform
As of 2014 the GT-R was the only model built on Nissan's Premium Midship (PM) platform,[15] an evolution of the Front Midship (FM) architecture introduced in its 2001 (V35) Skyline. It is a hybrid unibody assembled on ultra-low-tolerance jigs similar to those used in racecar construction. Alcoa aluminum is used for the hood, trunk lid and outer door skins, with die-cast aluminum front shock towers and inner door structures. Outer body panels are stamped using multiple-strike coining process for added rigidity and precision. The chassis is stiffened with a carbon-composite front crossmember/radiator support.
Exterior
Nissan developed a 6-stage paint process with double clear coat and chip-resistant paint for use in critical areas of the GT-R chassis. An optional liquid-effect finish employs a hand-polished 8-stage process with product-specific Super Silver metallic paint and three layers of clearcoat.
Optional features
The Premium Nissan GT-R has a body-colored rear spoiler whereas the Black Edition has a dry carbon-fiber rear spoiler. Both the Premium and Black Edition GT-R are fitted with high intensity discharge (HID) headlights, automatic on/off headlights, LED daytime running lights, LED taillights and brake lights, dual heated body-color power outside mirrors, power folding outside mirrors, flush-mounted aluminum door handles, four 5" exhaust outlets with polished tips and UV-reducing solar glass.[16]
For the 2014 model year, Nissan introduced a limited production Track Edition GT-R which deletes the rear seats (saving 22 lbs over the Black Edition) and adds more aggressive suspension, carbon fiber air inlets, improved brake cooling, a unique front spoiler, and new black and gray leather Recaro front seats.[17]
Specifications
The VR38DETT engine
The Nissan GT-R is powered by the VR38DETT V6 engine, a 3,799 cc (3.8 L; 231.8 cu in) DOHC V6 with plasma transferred wire arc sprayed cylinder bores.[18] Two parallel Ishikawajima-Harima Heavy Industries (IHI) turbochargers provide forced induction.[19] Models manufactured between 2007 and 2010 produce a manufacturer-claimed engine output of 485 PS (357 kW; 478 hp) at 6400 rpm and 434 lb·ft (588 N·m) at 3200–5200 rpm.[20] The engine also meets California Air Resources Board Ultra Low Emission Vehicle (ULEV) standards.[21] A curb weight of 1,730 or 1,736 kg (3,814 or 3,827 lb) with side curtain airbags is achieved using a jig welded steel chassis with aluminum used for the hood, trunk, and doors.[22] A rear mounted six-speed BorgWarner designed dual clutch semi-automatic transmission built by Aichi Machine Industry[23] is used in conjunction with the ATTESA E-TS system to provide power to all four wheels and along with Nissan's Vehicle Dynamics Control (VDC-R) to aid in stability. Three shift modes can also be selected for various conditions.[24] Beginning in 2010, engine power and torque were upgraded to 390 kW (530 PS; 523 hp) at 6400 rpm and 612 N·m (451 lbf·ft) at 3200–6000 rpm respectively. Models produced in 2012 again featured improved engine output (406.5 kW (553 PS; 545 hp) at 6400 rpm and 628 N·m (463 lbf·ft) at 3200–5800 rpm). In the near future, it is speculated that the GT-R might even be available as a hybrid.[25]
2011 facelift
A 2013 Nissan GT-R Black Edition with the updated design
The revised GT-R features an engine with revised mapping, changes to valve timing, larger inlets and a revised exhaust system which boosts rated power to 545 bhp[26] and 612Nm of torque from 3200 to 6000rpm. Changes also include a new more rigid front strut bar made from carbon composite, larger front brake rotors, new lighter and stiffer wheels, and revised Dunlop tires. Cosmetic changes include a new front bumper with integrated LEDs. The front bumper improves cooling to the radiator and front brakes while reducing drag. A new rear diffuser improves downforce and also includes additional rear cooling ducts. The interior was revised to improve the quality. This new version is offered with a new HDD CARWINGS navigation system with enhanced entertainment features and USB port with iPod connectivity. The revised GT-R went on sale in Japan from mid November 2010 and February 2011 in Europe, North America and other regions.
Old Jan 3, 2017 | 10:13 AM
  #172
Lartytiejdke3's Avatar
that gtr spoiler on a g35 looks like utter dogshit.
people are just bored with these cars now...
Old Jan 3, 2017 | 02:54 PM
  #173
saywat?'s Avatar
could be worse i guess lol
http://honolulu.craigslist.org/oah/cto/5943032801.html
Old Jan 3, 2017 | 04:06 PM
  #174
.cakestar's Avatar
Old Jan 3, 2017 | 04:33 PM
  #175
Originally Posted by saywat?
exactly
No one appreciates a simple, clean G (granted, when the G first came out it seemed more people did). Now we're Frankensteining parts off other cars and just sticking them on trying to be unique.
And we're failing miserably.
Old Jan 3, 2017 | 04:54 PM
  #176
saywat?'s Avatar
did you guys know that gundam robots played a role in the design of the gtr?
Old Jan 3, 2017 | 06:16 PM
  #177
so did the cobalt SS
See rear tail lights*
Old Jan 3, 2017 | 07:05 PM
  #178
Blue Dream's Avatar
Originally Posted by .cakestar
Now that's a mod I can stand behind, totally bad azz!!!
Old Jan 3, 2017 | 07:07 PM
  #179
Blue Dream's Avatar
exactly
One of the main reasons I'm keeping the GTO bone stock.
Old Jan 3, 2017 | 08:45 PM
  #180
Urbanengineer's Avatar
G35 was simply a GT styled car on the 3.5L platform. The GTR was a car bred from racing DNA and is on another league then our $35k sporty coupe.
I'm really digging that spoiler though. Sorry the others don't like it.
