G35 & G37, Coupes & Sedans
Suspension Woes
Old Jun 10, 2017 | 12:23 PM
canehdian_guy's Avatar
Suspension Woes
I have a 2007 G35 Coupe with about 70K miles or 115K km and the base model suspension.
I went to a shop to get my alignment done and was told they were not able to get my rear camber within spec, because my springs are worn out and sagging too low.
I havent heard of springs really needing to be replaced on on-road vehicles. I'm wondering if the previous owner installed 350Z springs.
Does anyone know how I would tell if my springs are worn out, or if I just have 350z springs?
Thanks
Old Jun 10, 2017 | 01:58 PM
ScraggleRock's Avatar
Thanks
springs definitely go bad. Give us a pic of your wheel well gap.
Old Jun 10, 2017 | 09:27 PM
Urbanengineer's Avatar
Fender distance to ground also, in the case of aftermarket wheels.
Old Jun 12, 2017 | 12:15 PM
Cool thanks. Actually rread an old post in which springs were replaced under warranty.
My phone cams broken but I'll find a way to upload a pic later.
What would you guys suggest as for replacing the springs go if I want to maintain the stock ride height?
I called infiniti and they want over $1000CAD for the springs.
Old Jun 12, 2017 | 03:59 PM
holy **** are you serious? Haha
you could just try to find a low mileage junker. I'm sure there's someone here with some stickers considering everyone here lowers theirs. Post a WTB thread, I'm sure you'll find some in no time.
Old Jun 12, 2017 | 05:13 PM
G35freaks's Avatar
Ill sell you mine for $800. That's a steal
Ill even throw in my S-Techs....
Old Jun 12, 2017 | 08:21 PM
Lol! I know it's outrageous. There's actually some on sale locally but I have no way of verifying the condition.
Actually does anyone know if there is a way to verify the condition of springs without installing them?
Old Jun 14, 2017 | 03:19 PM
Swaglife81's Avatar
If this wasn't a NTB I advise you to go there. NTB is one of the few places that have true state of the art equipment other shops don't have.
The only reason at all your car can't get back into spec in the rear is if your car was lowered another inch from stock maybe 1.5 inches. Or if you have warn bushings causing your camber issues.
I'm not sure what all was said and what you have done to the car. If they threw it on an alignment rack than they should have gave you a before and after spec printout. That way we can see what's going on or if they are idiots.
Old Jun 15, 2017 | 11:08 AM
IMfam0us's Avatar
I think maybe its time to just upgrade to some coilovers and maybe give yourself a slight drop. should still be able to get everything back in within specs
Old Jun 15, 2017 | 11:27 AM
I'm thinking about it. I'm pretty happy with the stock ride height though. The local track has pretty high curbs so it'd be easy to bottom out.
Right now I'm between picking up some KW V3's or Koni Yellows on stock springs.
Some guy on craigslist is selling his springs and shocks for $80. If I can do the install myself I might consider trying those out.
Old Jun 15, 2017 | 11:29 AM
One of the things I'm worried about with coils is clunking etc. The guy on craigslist selling his springs said the BC coilovers he installed starting clunking at 5000km.
Old Jun 15, 2017 | 01:38 PM
dEnbOy.GFM's Avatar
I have OEM sport springs sitting in my garage, about 20k km on them.
Let me know if you're interested, I'd almost be willing to give them to you for free if you pay for shipping hah. One less box in my garage =P
Old Jun 15, 2017 | 02:45 PM
LoSt180's Avatar
What is the current alignment spec? That way we could try to tell if Z springs are installed.
Highly doubt the springs have "settled". More than likely the thick rubber mounts the springs sit on have compressed, lowering the ride height a little bit. You can try to find new rubber mounts, or you can just pick up a set of SPC rear camber arms and toe bolts to get the rear back into spec. It's fine that you aren't lowered, they really just provide a slightly larger range of adjust-ability over the OEM parts. You don't even need SPC, heck even Rock Auto as adjustable arms rebranded under several brands, but look just like the SPC parts (Moog, ACDELCO, etc).
Old Jun 19, 2017 | 10:39 AM
Yes please, sir! PM'd
Old Jun 19, 2017 | 11:07 AM
Toe angles are all within spec.
Front camber: Left: 1.36° Right: either +1.47° or -1.47° (water spilt on page can't tell)
Rear camber: Left: 2.54° Right: 2.35°
You might be right about those mounts though. I notice heavy clunking in the rear over bumps. Would that be due to mounts?
I'll look into those camber kits if the springs dEnboy.GFM kindly offered and the mounts don't fix the issue. Either way I'm excited for those sport springs increased rear rate thanks again, dEnbOy!!
