G35 & G37, Coupes & Sedans
First time going to a mechanic shop in 7 years..
Old Jul 19, 2018 | 10:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah you should just stick with the dye with the nitrogen you need a manifold that will connect the tank to the high/low lines and I usually charge to like 50psi then check for leaks.
​​​​​​You can use the soapy water trick with the dye as well but a black light should reveal it also I think.
Wannabe6MT
Mar 1, 2011 07:09 PM
Wannabe6MT
Oct 13, 2009 10:05 AM
G35fromPA
Autocross/Road
Jun 13, 2005 11:33 AM
