G35 & G37, Coupes & Sedans
sport pads for the rear?
Old Aug 4, 2022 | 02:45 PM
LEarn912's Avatar
pretty stock g35x. putting sport brake pads in
Sport pads on rear?
Hi i have a 2006 g35x that i just got. i put sport pads in the front becuase i used them on my old car and loved the extra power that they gave me. i need new rear pads too, my question is will putting sport pads in the rear mess up my car's handling or braking? like it won't mess with the brake bias, the system that alters brake pressure to each wheel, make my car more likely to fishtail or anything like that when i hit the brakes in a corner right? it'll just give me more stopping power? i'm thinking this as all the companies sell sport pads for rear too. anyone here done this before? any tips? thanks.
Old Aug 4, 2022 | 02:47 PM
LEarn912's Avatar
Old Aug 4, 2022 | 05:40 PM
projectpanda13's Avatar
if the pad material/compound is the same as the front, you will have no worries as it keep the factory brake bias.
changing the material/compound to bemore aggressive can change the bias but most liekyl won't be enough to affect significant change as the calipers are still larger up front to keep the bias.
Old Aug 5, 2022 | 12:09 PM
2003G35stock's Avatar
G35 Manual
It is not going to hurt anything. there is a bias so the front brakes will take the brunt of the force. No worries. Swap pads as you wish.
Old Aug 5, 2022 | 08:01 PM
LEarn912's Avatar
ok so i won't be breaking the rear loose on turns when i brake with these or other undesirable/weird traits?
Old Aug 6, 2022 | 03:23 PM
MooseLucifer's Avatar
5 Year Member
blk
The stock brake bias tends to lock (or in this case engage ABS) the front wheels before the rear. By increasing the friction coefficient of the front brake pads, you further increase this likelihood, which lends towards understeer. By swapping to sport brake pads in the rear, you'll be restoring the factory Front/Rear brake balance.
Old Aug 6, 2022 | 08:37 PM
G35 Manual
The rear brakes only supply about 20% of the braking power, so different pads will make little to no difference on the street.
Old Aug 13, 2022 | 10:58 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Merging your two threads, no need to make duplicate posts for the same question in multiple subforums.
Chris Topher
Jan 24, 2019 03:02 PM
newbdriver01
Jan 14, 2015 10:39 PM
mikw73
Oct 10, 2011 04:56 PM
