G35 & G37, Coupes & Sedans
Is removing dash worth it?
Old Jun 25, 2023 | 11:58 PM
anthony_mazzone's Avatar
It is a 2006 G35 Coupe with aftermarket Stillen Catback Exhaust and Air Intake, aftermarket radio
Lightbulb Is removing dash worth it?
I have a 06 G35 Coupe with some cracking and gashes in the dash that I want to hopefully fix. After looking at all the options, I came to the conclusion that there is only three valid options: dash cover overlay (which looks ugly), filling in the gaps and painting, or flocking it (which seems like the best cost effective option). Unfortunately, I would have to remove the dash in order to properly coat and flock the dash. The dash removal is a bit intensive, so I was even debating if it is even worth it to do it. What do you think? Should I say screw it and leave it or should I try to tackle it?
Old Jun 26, 2023 | 03:48 AM
Scorpi0's Avatar
I filled mine with some rtv. Then bought identical vinyl material and color as my dash. I applied glue over the old dash and then put the new skin over it. It came out looking like OEM. Just dont pull the vinyl tight or else it will eventually try to shrink and expose the edges. My mistake on that one. Still looks better than before though.
Old Jun 26, 2023 | 09:50 AM
@Scorpi0 I assume you had to remove the dash, right?
Old Jun 26, 2023 | 02:57 PM
Scorpi0's Avatar
Nope. Just the AC vent covers and the clock assembly. I used some small plastic scrapers to push the vinyl into the corners.
Old Jun 28, 2023 | 04:31 PM
wjdthird's Avatar
G35x
Scorpio can you elaborate a bit on this please I would like to do the same to mine,
thank you for your time you can DM me or whatever is easiest for you.
thinkricky
Interior
Jan 15, 2018 07:36 AM
beniscooler850
Interior
Sep 19, 2012 04:34 PM
mali_mG
Interior
20
Aug 15, 2011 07:49 AM
tgenius
Feb 24, 2005 11:14 PM
