What do you hate about YOUR G35?
#860
That the A/C turns on when you hit "Auto" even if it's freezing outside (does 1st gen do this too?).
The "ON" light by the starter button is orange and very obnoxious... it looks like a warning light. Doesn't match the red and blue lights on the rest of the center console.
Rear shoulder belts flap when rear windows are open.
#864
the seat belt doesn't retract and it's also scratching my door.
the bose stereo. cd's got jammed so i replaced it with another original stereo and now i can't get it to display anything. i believe it's the ribbon that connects from the stereo unit to the face. help? i need it bad.
not good on gas.
a raddle, semi squeek, noise at times.
even one day after washing the car, if i put the windows down then bring them back up, they will still be wet.
not good on gas.
#865
It can be a little noisy as when i press in the clutch all the way it had this humming sound. I got this rattle coming from my sun roof somewhere which i need to get fixed...hopefully the dealer will fix it. The main annoyance is the really high clutch "sweet spot." Maybe i should try that clutch mod...
#866
not good on gas.
not good on gas.
#867
#870
Originally Posted by paky786
You plugged the ribbon in right? If it's ripped even alittle, it can make a difference! Check all fuses
