G35 & G37, Coupes & Sedans
Dealership wants $110 for MT oil change ??
Old Oct 20, 2005 | 09:02 PM
niteQwill's Avatar
Am I getting rip here ? Are you F**king kidding me B ? $110 for a transmission oil change ? It cant be that much of a difference from changing motor oil. Dealerships i tell ya
Old Oct 20, 2005 | 09:23 PM
sngpimpin's Avatar
wait tranny oil or just engine oil change? there is a difference there. a oil change shouldnt cost more than around 38 bucks
Old Oct 20, 2005 | 09:40 PM
niteQwill's Avatar
What im asking is the labor for changing transmission oil shouldnt be that difficult rt ?
Old Oct 20, 2005 | 10:31 PM
s14roller's Avatar
Tranny oil change is probably a bit more than a regular oil change
Old Oct 21, 2005 | 08:55 AM
Dieselnuts's Avatar
unless the tranny has a fluid plug, the entire tranny pan has to be dropped. Its a really dirty job if you dont know what your doing. the gasket has to be replaced too. I dunno about 110, but i know it would be atleast $85. After all, thats why I call it the Stealership....
Old Oct 21, 2005 | 09:27 AM
sofl_g's Avatar
It's a 6MT, so there's no pan. It will have a plug to drain and a plug to fill. That is rather steep for less than an hours work.
Old Oct 21, 2005 | 12:22 PM
GsUpHoesDown's Avatar
Diy.
Old Oct 21, 2005 | 12:48 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Diy...+2
Old Oct 21, 2005 | 12:56 PM
some.devil's Avatar
diy +3
Old Oct 21, 2005 | 06:38 PM
sybertel's Avatar
If you DIY, which is what many would be tempted to do, be sure to have the exact right oil for your transmission.
There are many many cars with MT's that have never had a gearbox oil change. Is there some reason that it is being recommended to do this service?
Old Oct 22, 2005 | 01:45 AM
G352NV's Avatar
Never enough
man this is as easy as changing the motor oil! DO IT YOURSELF! While your at it do the rear end, its just as easy!
Old Oct 22, 2005 | 01:58 AM
Msedanman's Avatar
O.F. Administrator
Hahahahaha...... They're definitely trying to shaft you, mate....if you don't want to do it yourself, go elsewhere.....
There's about 2 quarts of oil in there and should take about 15 minutes to change.
C.
Old Oct 26, 2005 | 02:15 AM
ZeroGen's Avatar
Omega Enthusiast
Changing the tranny oil is as easy, if not easier than changing the engine oil.
11bEMT
May 27, 2022 03:13 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
