G35 & G37, Coupes & Sedans
air tire sensor?
Old Oct 25, 2005 | 07:45 PM
nwrzG35's Avatar
air tire sensor?
well i bought new wheels and i have air sensors on my stock oem wheels. my question will some sort of light or signal turn on on my dash if i'll be using a different set of wheels with out the air sensor in them? also,is it possible to transfer the sensors to my after market wheels, or do they only work with our oem wheels?
one more lol...i bought 19x10 with a 35mm offset..will this rub? i was really lucky to get a pair at a cheap price and the only offset available was 35mm for the front and rear, i just want to make sure that these will not rub or will i have to cut my fenders? i'll be running 375/35 and 245/35 thanks
Old Oct 25, 2005 | 09:05 PM
dave's Avatar
If you drive without the tire pressure sensors in the wheels, there is a light on the dash that will come on after driving for 30-45 minutes of continuous driving. It turns off again when you turn the car off.
From what I've read, the sensors fit on some wheels, and not on others.
You might get better responses over in the Wheels & Tires forum.
Old Oct 26, 2005 | 07:21 PM
skylar's Avatar
im currently running aftermarket wheels without the air sensors... when i first put the wheels on the light came on after 20-30 mins of driving. but now whenever i start my car the tire pressure light starts flashing for a minute or so then it just stays on. yes, its possible to transfer the the sensors over to aftermarket wheels.
Old Oct 27, 2005 | 01:59 AM
Strider_GTS's Avatar
My lights have been on for about a month now. I just ignore them...
It's really cold here lately.
Old Oct 27, 2005 | 08:17 AM
giddyup69's Avatar
light is on because u don't have sensors or because your low on air?? if low on air u need to pump those suckers up otherwise u'll get uneven treadwear and crappy gas mileage.
Old Oct 31, 2005 | 10:42 PM
BrnSilk's Avatar
[IMG]file:///C:/WINDOWS/Desktop/Cars/My%20G/angled%20g.jpg[/IMG]
Old Nov 1, 2005 | 09:17 PM
Duy's Avatar
Duy
the light comes on in cold weather... its a real common problem for the G. mine usually comes on when its 40-50 degrees or below
Old Nov 1, 2005 | 11:07 PM
Black Mammoth's Avatar
Air pressure is directly effected by air temp. Your pressure will be lower in the colder weather. However, it won't fix itself. You should inflate the tires to the proper pressure. Not only is it safer, you will get better gas mileage and wear. You should check the air in your tires often; basically you should ensure that you never see the dummy light. Also, you shouldn't take the 35psi all around for face value. You should monitor the tread on your tires and find the best tire pressure for your tires. 35psi is a good base line to start. I know this is getting slightly off topic, but some of the replies concerned me.
Muski_G
Dec 1, 2023 11:11 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
derres
Aug 28, 2015 03:27 PM
stay_tuned
Jul 21, 2015 07:09 PM
