G35 & G37, Coupes & Sedans
Coilovers on 06 MT...wat do u think?
Old Dec 27, 2005 | 03:53 PM
Luv2xcelR8's Avatar
i have a 2006 G coupe 6MT but i want to lower the car...i dont want to cut the suspension life down so i am looking into getting the eibach adjustable coilovers or H&R...any suggestions or experiances with either of the systems?
Old Dec 27, 2005 | 07:52 PM
kenchan's Avatar
if you're thinking about a full swap, why do you care about the
longetivity of your stock struts? is this a leased car?
Old Dec 28, 2005 | 01:19 AM
Luv2xcelR8's Avatar
know its baought but if i put lowering springs on it eventually it will mess up the suspension so i think im gonna just go ahead and get the tein basic coilovers
Old Dec 28, 2005 | 07:06 AM
akrus's Avatar
Doing springs alone would also have your stock struts operating outside of their intended range which will not give the best ride.
You're making the right choice in doing coil overs.
Remember, it's not all about looks - the performance has to stay the same or, ideally, improve.
Albert
Old Dec 30, 2005 | 12:29 PM
Jahan's Avatar
??? Explain this.
Also, if this is true, why WOULDN'T coil-overs mess up your suspension?
Old Dec 30, 2005 | 01:51 PM
papagz's Avatar
Originally Posted by Jahan
??? Explain this.
i THINK he means the stock shocks/struts would get messed up b/c they are made to work correctly and last longer at a certain ride height/dampening/spring rate etc. but i could be wrong
Old Dec 30, 2005 | 08:38 PM
Luv2xcelR8's Avatar
wat he said^
Old Dec 31, 2005 | 10:02 PM
Galikanokis's Avatar
To get all technical, lowering changes your motion ratio and it's linearity. The vibrations now come into the car through slightly different paths, and similar for the forces.
Old Jan 2, 2006 | 06:25 AM
supag116's Avatar
IF you were to keep your stock struts healthy without swapping out for coilovers, why not try putting on Tanabe DF210 Springs. They lower your car 1.5" (claimed) and, unlike most springs out there, these ones have similar spring rates as OEM ones.
Old Jan 3, 2006 | 06:16 PM
Luv2xcelR8's Avatar
that would pobably be fine and work out^ but im not willing to take the chance so i think im gonna go coilovers..iv heard alot of good things about tanabe though
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
