G35 & G37, Coupes & Sedans
Installing grounding wire to battery?
Old Jan 6, 2006 | 06:16 PM
99atlantic's Avatar
For anybody whose installed grounding wires, is there some way to feed the grounding wire that goes to the battery under or sideways or something into the battery box w/o having to punch a hole in the battery cover?
Old Jan 6, 2006 | 06:39 PM
RBull's Avatar
Rated M
The hole doesn't go in the battery cover. It goes in a rubber grommet leading to the battery compartment. Sorry my G is stored somewhere else now or I could give you better directions. You might find a DIY somewhere here if you try a search or someone here will likely respond soon to help you. You won't notice the hole in the rubber. If done carefully and properly it looks like a factory access for the grounding wires.
Good luck.
Old Jan 6, 2006 | 06:47 PM
99atlantic's Avatar
oooooh, this picture makes so much more sense now that i know that's a rubber gromet entry point:
Old Jan 6, 2006 | 06:52 PM
RBull's Avatar
Rated M
Glad to help Atlantic. It's not actually a grommet, more a place to make a cut. When making the x cut use a heavy duty utility knife. Be firm but very slow, deliberate and careful cutting as once it breaks through the knife will very easily cut a huge hole you don't want.
Old Jan 14, 2006 | 08:57 PM
99atlantic's Avatar
okay, slight problem - i actually went and looked at the car today (2003.5 model) and there's no rubber gromet to cut - the battery box is basically one solid plastic box, with 3 or 4hoses going into the side of it - i have no gromet to cut like in the picture....WTF?
Old Jan 14, 2006 | 09:17 PM
99atlantic's Avatar
okay, nevermind, apparently I have to cut a hole right above where the positive battery cable enters the compartment.......AJ is scarred to cut into it now :/
chinee
Jun 10, 2024 07:48 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
willdogs
Dec 8, 2015 11:32 AM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
dimentio1
Aug 16, 2015 11:47 AM
