G35 & G37, Coupes & Sedans
Weird engine sound - goes away when clutch pressed
Old Jan 23, 2006 | 04:55 AM
mistermojorizin's Avatar
if i drive around for a bit and then stop the car, ther's a sound that can be heard from inside the car and from the outside. It definitely sounds like somthing is hitting something else. When I press the clutch, the sound goes away.
Anyone familiar with this? btw i have a 05 coupe.
Old Jan 23, 2006 | 05:02 AM
I Scare's Avatar
i don't know about you, but i have this problem when the car makes this noise when i drive it the very first time. For example, if i start the car, and then drive it, i'd hear this quick noise and it goes away. But the noise only occure when i start my engine to drive. If i don't shut down my engine, the noise won't re-occur. It only occurs once when i start the engine and then press the gas pedal, the noise comes up.
Old Jan 23, 2006 | 01:02 PM
Msedanman's Avatar
O.F. Administrator
Probably tranny noises, thow-out bearing, gears, syncros etc. If it's functioning properly, don't worry. You're going to hear noises in them.
If the tranny isn't shifting properly, have the dealer evaluate it.
G/L
C.
Old Jan 23, 2006 | 01:04 PM
Msedanman's Avatar
O.F. Administrator
What you can hear is the VDC self test done shortly after start-up.
No worries.
C.
Old Jan 23, 2006 | 01:19 PM
luongdmd's Avatar
it's normal if it's the tranny.... we all have that problem.... if there's a performance issue.... take it in.....
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
leo38cheng
Nov 12, 2015 06:49 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
ghost_g35
Aug 7, 2015 10:31 AM
