G35 & G37, Coupes & Sedans
Question about oil filter and flow
Old May 19, 2006 | 12:48 PM
ballisticus's Avatar
The Noack Volatility index is key to consumption. This is a good comparison of major oils.
http://www.amsoil.com/performancetests/g1971/
Personally, I use the M1 5W/30 extended performance. It is almost equal to the Amsoil and is available for $26 for 5 qt. jug at WalMart. I dont think you can get a better oil for the price. I run the EP for 10K miles between changes with about 1 1/2 qts. added in that time. I really dont see the benefit of RP in a street car. Seems like its a racing oil that gets dumped after every few races anyway so volatility/consumption is not a concern to them.
Old May 19, 2006 | 01:02 PM
JerryD's Avatar
Originally Posted by DesertRat
I have noticed this sometimes too. I use mobil one synthetic and purolater (or something like that) oil filters. 2 quarts seems to be the maximum. I had the dealer do an oil consumption test and they said it was ok. I don't know. I have a hard time believing that my almost new motor is burning that much oil.
are you checking oil level on hot/warm or cold engine?
the rule is:
engine oil - cold
transmission - warm/hot
Old May 20, 2006 | 05:57 PM
whyjay91's Avatar
Great posts. Thanks for all of the info. Maybe it's time to switch back to M1.
Thanks again.
Old May 21, 2006 | 03:15 PM
DesertRat's Avatar
the rule is:
engine oil - cold
I'm actually not talking about when I check my oil. I mean when I do an oil change, only three quarts of oil come out. I still have the old oil and it is as cold as it's going to get and still only three quarts. It goes to the dealer on monday for this and some other small stuff. They will probably reluctantly do another test and they will probably say nothing is wrong.
Old May 21, 2006 | 03:56 PM
Texasscout's Avatar
if you are 2 qts low, it should show on the dip stick. If it's not, you have another problem.
Gookiecrunch
Aug 19, 2015 12:00 PM
linedr89
Aug 17, 2015 05:11 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
