AnYone with an auto have any clicking axle issues?
Old Sep 11, 2006 | 01:21 AM
NYCG35's Avatar
G SQUAD
Just aksing if anyone with a 5AT has had the clicking axle issue that I hear the 6MT's have
sedan or coupe..post please
Old Sep 11, 2006 | 09:45 AM
LEK's Avatar
LEK
That Guy
A couple of the ngc guys with auto had the problem on their car. But got it fixed under TSB.
Old Sep 11, 2006 | 09:46 AM
Garyv01's Avatar
had it..went to dealer...left it...and now its fixed...best part=FREE! lol
Old Sep 11, 2006 | 01:20 PM
ducatiguy's Avatar
Premier Dough Slapper
The infamous "clicking rear g's".... Don't worry about it! Infiniti knows about it, and they'll cover it. All that Infiniti has to do to get rid of the clicking noise is regrease the rear axles. THATS IT! In doing so though, Infiniti replaces all the axle bolts, which is why in most cases it takes a day or two for you to get your car back (they often dont have the bolts in stock). Could they reuse your old bolts and give that car back to you in one hour, yea, but Infiniti feals bolts on a axle, since they're always exposed to such high amounts of force / torque, should be replaced upon removal, and I agree. Could you get away with using your stock bolt instead of new ones without problems, 99% positive you could, but for Infiniti it's not worth it. Its there way they cover their rears (no pun intended).
The clicking noise is also NOTHING dangerous or anything to worry about in terms of will your axle break or come apart. Its just a really annoying defect (not enough grease from the factory), that has a really easy cure, but when you're at the mercy of the dealership for a warranty job, nothing is fast and easy....
Old Sep 11, 2006 | 01:22 PM
seddon's Avatar
HELL yeah!!!! Just had the dealer fix it.
Old Sep 11, 2006 | 01:47 PM
NYCG35's Avatar
G SQUAD
THanks fellas....I dont have it ...YET....but I just wanted to know if the auto's get it too ...because I have just heard about it on the 6MT's
but I guess no one is immune
Ducati aka John....hey man now THAT is a freakin response....informative and detailed....!
I know the dealers know about this ...as they do every other issue with this Pretty azz P.O.S - oops did I say that outloud....LMAO
anyways just wanted to know if the autos are getting it too...and I guess so
oh well....I'll just drive it more to hurry the issue along...so I can get it fixed
Old Sep 11, 2006 | 04:40 PM
silvsurf's Avatar
Yep, I have an 03 auto and had it fixed about 2 years ago. They just re-lubed the rear axle. No problems since.
Old Sep 11, 2006 | 05:17 PM
absolutg's Avatar
workin...
the clicking occurs during movement? or when? like after you push down on the brakes? i get a click then but i figured that's just the brakes
Old Sep 11, 2006 | 06:22 PM
ducatiguy's Avatar
The sound almost always (if you have the problem) happens between fwd and rvs shifts, like when you're going to back into a parking lot or when you're trying to do a quick K-turn. Its sudden changes from fwd to rvs that start the clicking. The clicking is also almost never heard at cruising speeds above 20 MPH. It's most evident at crawling, or parking lot speeds under 15 MPH. If you're hearing clicking at higher speeds above 25-35 MPH, its quite possibly a more serious problem, and you should have it looked at. The clicking noise is also very "tin-like" or "pick-sounding" and not "dead-hard" or raw (which you would get from lets say a bad bearing), which would be signs of something more serious. Best advice, if anyone has any unnusual sound coming from the rear of the car, take it in for service ASAP.
Old Sep 11, 2006 | 07:49 PM
VinNYCG's Avatar
G SQUAD
Yep this is the issue I was having on the 04 sedan as mentioned in a prior thread which is auto. I also had this issue on the my old 03' coupe. I'm bringing in the sedan sometime this month to get the prob. resolved.
- Vin
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
mtlruss
Dec 20, 2015 01:51 PM
Frostbite91
Aug 20, 2015 07:20 PM
wuppiedog
Aug 7, 2015 11:16 AM
joedaddy1
Jul 28, 2015 02:58 PM
