Installed Component Speakers
Old Sep 25, 2005 | 01:16 PM
pdjafari's Avatar
great job, with those extra spacers was there any problem replacing the door panel back on?? I guess how much depth are you able to work with?? And could you have made the MDF ring thicker/thinner?? I might want a set!!
Old Sep 25, 2005 | 01:51 PM
ducatiguy's Avatar
Premier Dough Slapper
There's actually a lot of room to work with within the door panels of the G. Loads of "empty" space. The ring can be made thinner, but there's no need, and since most components are larger (depth wise) than the cheap-azz Bose woofers, you'll want all the air space you can get. Once you get in side the panels and pull off the OEM Bose woofers, you'll see what I mean....
Old Sep 27, 2005 | 01:54 AM
SI_G35Coupe's Avatar
conklin... yea i can make another set... shoot me a PM
pj.... there's plenty of depth... and actually, the 3/4" MDF brings the aftermarket woofer to almost exactly the same spot as the stock woofer... it lines up perfectly with the gasket on the backside of the door panel
Old Sep 27, 2005 | 11:45 AM
G35scBkNy04's Avatar
G SQUAD
Looks good Steve, I bet the sound is incredible...
Old Oct 2, 2005 | 06:24 PM
jmugoose30's Avatar
poat
Old Jun 17, 2009 | 11:07 PM
shdowflare's Avatar
Getting ready to order the Kappa component speakers as door replacements for my '03 G coupe now, and the 6.5" 62.9is for the back as well. Do I need the speaker spacers for just the door speakers only, or on both rear side panels as well?
Old Jun 17, 2009 | 11:20 PM
seddon's Avatar
Bro this thread is almost 4 years old.
You need spacers if your speakers are deeper than your door. Most people install them to have a solid mounting surface.
Old Jun 17, 2009 | 11:23 PM
shdowflare's Avatar
Thanks, guess I should've opened a new thread. So to be safe, I guess I should buy them for both the front door and rear trim finisher speaker mounts, right?
Old Jun 30, 2009 | 02:26 PM
shdowflare's Avatar
Done deal, Zen 1" speaker spacers were money for both front and back sides.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
WillisFL
Dec 29, 2016 08:56 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
justgotg35
Jul 19, 2015 12:33 PM
