test pipes
Old May 9, 2006 | 01:08 PM
MaxxZ's Avatar
test pipes
How hard is it to install test pipes. Has anyone paid to have someone install theirs? If so, how much and where?
Old May 9, 2006 | 02:19 PM
drunkin master's Avatar
I have heard from people that it was pretty easy to install with the right tools.
do a search and you should find all the info you need. I think most places charge around $50 to $60 per hour. I was planning on getting them to and they said that it takes about an hour.
Hope this helps.
Old May 10, 2006 | 12:21 PM
MaxxZ's Avatar
The guy at the exhaust place by me told me he would charge me $85.00 per side to install a set. He said he would make me one himself and install thenm for $400.00. Does that installation cost sound a little high? I dont have ramps or a lift so doing it myself may not be an option.
Old May 10, 2006 | 09:15 PM
marchesano's Avatar
www.g35tt.com
If you have jack stands, do it yourself. You have to unplug the O2 sensor, and take off 4 bolts (2 on each flange). The hardest part is how baked on the gaskets are to pry off. Really easy. Give it a try first, and if you can't so it, take it somewhere. You will always get more satisfaction doing it yourself. If you need any advice, just PM me.
magnetism80
Jan 27, 2016 12:57 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
