how much does it cost to drill 2 holes?
hi squad, i just got CF hood,and need to install the hood pins.
wounder if u done drilling the hole in CF for hoodpins any tips will deff help alot, and how much do u think it will cost?.
i went to a shop..qouted me 100 BUUUUUCKs. JUST TO DRILL 2 HOLES?
(i have the hood pins myself,but needed to be install)
It's not that hard. I would install the pins on the rad support and then put grease pen or someting on top of the pin and set the hood down on it to make a mark on the hood. Set the pins as low as possible when you install them for the marking. Then using electrical tape, tape the **** out of it before drilling. Use sharp bits and don't apply a lot of pressure.
Drill up small from the bottom and then move up top for the other drilling as you go bigger on the bit.
