FS: Custom Twin Turbo g35 6spd Caged
Selling my Track/show car.
I have owned this car since 2009, and have never planned to sell it.
The car is overall in 9 out 10 shape, the items that could use a little tlc are, there is a light scratch on the front left fender, some of the plastic trim pieces under the door the paint is chipped, the inside of the driver side tint has a scratch on it( not to noticeable) and the car could use a retune, It was tuned cattless, however I have installed HFC on it, which changed the tune a little under mid boost in the mid range, other wise WOT and driving around town it runs strong.
If that hasnt scared you away here are the highlights of the car.
Won Numerous first place awards and shows, as well as no expense was spared.
I had set this car for a Track set up, in which the roll cage is full scca spec,(ready to complete) After building it I didnt have the time for track days any more so had a custom sub set up placed in the rear of the car.
I am pretty firm on the price but willing to negotiate for a serious buyer,
I can take the big parts off to lower the price IE engine/turbo, Rims, suspension.
Cash only, no SHIPPING NO SCAMS NO TRADES no Payment plans.
25,000 as-is and smogged
Willing to bring the price down,
I can remove rims, seats, suspension to get the price in the mid teens.
Exterior:
Custom 1 of a kind Front Bumper
Custom CF Front Splitter (has scuffs and a crack on it)
Custom 1 of a kind Rear trunk
Custom 3 Stage Paint Audi Base with Pearl
Custom 1 off hood with GTR Carbon Fiber Hood Bonnets
Custom Quick Release for bumper
Paint Matched door handles
Nismo Side Skirts
Nismo Rear Lip
Jdm Window Visors
Shaved Door Trim
Painted Window Trim
Blackout Projector Head Lights
Shaved Trunk Emblem
Custom Emblem less Grill
Custom Kandi Painted Akebono Calipers.
Custom Kandi Paint Sway Bars and Brackets
Custom Kandi Paint Front Liscense Plate
Custom Widended Rear Fenders
Carbonfiber Front slipper with APR rods
Gloss black Vinyl Roof
Engine:
Wiseco Pistons .020 over
Eagle H Beam Rods
ARP Rod Bolts
Block redecked
Block Bored and Honed
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Heads redecked
Ported exhaust and intake runners
JWT S7 Revup Cams
JWT Heavy Duty Valve Springs
5 Angle radius cut valve job
Mrev2 Intake Manifold Powder Coated
Power Labe 5/8th Spacer Powder Coated
Ported Lower runners
Greddy 18g Twin turbo kit
Thermal coated manifolds
Custom 3inch True Dual Exhaust
Deatschwerks 600cc injectors
Aeromotive 340lph in tank fuel pump
Koyo 32mm aluminum radiator w/ Koyo radiator cap
Custom Oil Cooler
Custom Power Steering Tank
Custom oil catch can
Custom full wire tuck w/ unnecessary holes & brackets shaved
Earl's steel braided hoses and fittings
Hose Techniques couplers & clamps
JDM drivers side battery cover -- modified
Timing Chain cover Powder Coated
Replaced 200+ bolts w/ polished stainless steel allen bolts
Samco Hose kit
Nismo Clutch Type LSD Diff
466 whp on 7.5lbs boost.
Suspension:
Akebono BBK 4p 14" front -- 4p 13" rear ( Custom powder coated)
Stainless Steel Brake lines
KW Racing V3 Coil Over system
Custom Swift Spec R Race Springs upgrade
Stillen sway bars front & rear (Custom Powder coated )
SPL Pro Solid Compression rod bushings
SPL Pro front & rear adjustable sway bar end links
SPL Front Camber Arms
SPL Rear Camber kit
Prothane front control arm bushings
Prothane sway bar bushings front & rear
Prothane Rear Differential Mount
NRG upper front strut bar
Wheels / Tires :
GramLight 57xtreme -- 19 X 9.5 +25 front : 19 x 10.5 +25 rear
Toyo R888 -- 265 / 30 / 19 Front : 295 / 30 / 19 Rear
Interior:
Recaro SPA Bucket Custom heated seats*
Custom mounted AEM True boost, oil pressure, A/f Gauges
Interior plastic pieces painted black color
380rs Z gas Pedal
LED lighting
Full 6 point Race SCCA Approved Track Roll Cage
Custom Painted Passion Purple
Crow 6 point Racing Harnesses
Custom Rear Seat Delete
I.C.E:
Alpine S920HD Double-Din Indash Nav
Focal 165A1 Component speakers In front
Focal 165CA1 Speakers In Rear
JL 12w6 Subwoofer
Custom Rear Sub Enclosure Rear Seat- Lighted
Alpine PDX-v9 5 Channel Amp
Back up Camera
More pics can be seen at
www.g35forsale.com
Exterior:
Nismo Side Skirts
Nismo Rear Lip
Jdm Window Visors
Shaved Door Trim
Painted Window Trim
Shaved Trunk Emblem
Engine:
Eagle H Beam Rods
ARP Rod Bolts
Block redecked
Heads redecked
JWT S7 Revup Cams
Custom Oil Cooler
Samco Hose kit
Suspension:
SPL Rear Camber kit
Wheels / Tires :
Interior:
380rs Z gas Pedal
LED lighting
I.C.E:
JL 12w6 Subwoofer
Back up Camera
www.g35forsale.com
Parting car as well, New pricing
WILLING TO TRADE FOR JAPANESE CAR/WAGON/SUV OF LIKE VALUE OR HIGHER, Must be automatic and clean title
5k obo Full Greddy 18g kit plus intercooler kit, thermo coated manifolds, painted piping
2000 obo kwv3 coilovers with swift linear spring upgrades
750 obo spl front and rear camber arms
1200 obo + stock dual piston brakes and rotors, for my Kani painted Akebonos and adaptor brackets
300 obo plus stock g35 koyo radiator
2800 obo Gramlight 57xtreme with toyo r888 265/295 less than 400 miles on them
I can also sell the car as low as 15k with some of the good removed, IE wheels, turbo, supsions.Will put stock wheels, lowering springs, headers. etc
laksjd84
Jul 24, 2015 05:12 PM
