FS: 2007 G35 Coupe 6MT - Veilside Widebody & more
SOLD
Interior:
Interior:
- Nissan double din finisher and dual ac control
- Pioneer Avic z110bt
- Nissan steering wheel airbag cover
- Nissan Skyline kick plates
- VeilSide Fortune Widebody Kit (molded quarter panels)
- VeilSide Fortune full carbon fiber hood
- Mastergrade MG2 full double sided carbon fiber trunk
- Custom retrofitted factory gas filler neck, door and locking mechanism
- Fiberglass emblemless front grille painted black
- Nissan front bumper clear side markers with bump
- Nissan rear tail lights with trunk button (jdm)
- Painted Bianco Fuji Pearl White
- 20" iForged Neo wheels painted matte black face, gloss black lips
- SPL v3 front upper control arms
- SPL Rear camber links
- SPL Eccentric lockout kit
- Custom CAD designed rear spring buckets with SPL adjustment joints (toe adjustment)
- BC Racing coilover shocks
- Accuair Suspension e-Level (electronic leveling) system
- Universal Air Suspension front + rear bags
- Hotchkis front and rear sway bars
- Whiteline front end links
- SPL rear end links
- Energy Suspension compression rod bushings
- Nissan Akebono big brake kit
- Front cross drilled and slotted rotors
- Upgraded front and rear stainless steel braided brakes lines
- Nismo pilot bearing
- Chromoly pivot ball
- Jim Wolf Technologies Flywheel
- Southbend Stage 3 Endurance TZ Clutch
- Upgraded stainless steel braided clutch line
- Berk Technology High Flow Cats
- ExoticSpeed R1-T Exhaust
- Vortech v2 Supercharger (Upgraded to polished blower and Si-Trim)
- Vortech 2.87 pulley
- Upgraded Vortech bypass valve.
- Timrod's Vortech stiffener kit
- Deatschwerks 850cc injectors
- Uprev MAF GT
- Motordyne Mrev2
- Motordyne 1/2" iso thermal plenum spacer
- Mishimoto aluminum radiator
- Mishimoto aluminum radiator fan and shroud kit
- Stillen Engine Damper
- Custom aluminum coolant overflow tank
- Custom power steering cooler kit
- IPP Stage 2 Rev-Up long block with extras (9.5:1 compression)
- Wiseco Pistons .020 over
- Eagle/SCAT H Beam Rods
- ARP Rod Bolts
- Block inspected and cleaned
- Block redecked
- Block modified for better cooling with HR Headgaskets
- Block Bored and Honed using a Torque Plate
- Rotating assembly balanced
- Crank magnafluxed and the journals micro-polished
- New Moly coated Race Spec main bearings installed
- New Moly coated Race Spec rod bearings installed
- Block assembled
- New Cosworth HR Head Gaskets
- Heads inspected and cleaned
- Heads redecked
- Ported exhaust and intake runners
- JWT S7 Cams
- JWT Heavy Duty Valve Springs
- 5 angle radius cut valve job
- New OEM Valve stem seals installed
- Valve Stem Heights set
- Cold Clearance set for cams
- Heads assembled
- New OEM Rev-up Oil Pump
- ARP L19 Head & Main Studs
- Jim Wolf Technologies oil span spacer
proud new owner
im a proud owner of this 35
somehow i got lucky buying it for a good price from this small town dealership in mn the owner bought it at a auction idk full story but all i know shes in good hands now and with the rest of my nissan family gtr r32 370z 300zxtt and 240sx s13
Update on my end - as much as I didn’t want to sell the car .. I simply had to and it was the best decision that I’ve ever made. Money went to my savings and I was able to buy a home in San Francisco with an interest rate of 2.625% 😂
