SES after oil change?
Old May 23, 2006 | 02:03 AM
diablo1356's Avatar
ok guys i need some help....i just got my oil change today and put in valvoline synthetic like i always do...i also got this package they have where they clean the fuel injectors, intake system, and something else (i cant really remember)..anyway everything was fine and then all of a sudden i started my car and the SES light was on...i had taken it on a spirited drive just before..about an hour later i turned it back on and theres the light...ok so i did the ecu reset and the light is gone...but ive noticed that the car is idling at a slightly higher rpm...it used to hover around 400 now its at like 800...anyone know what i should do..im gonna take it to autozone tomorrow and have them check with the ecu diagnostic...but im not sure if anything will come up since there is no SES light anymore...help!!
Old May 23, 2006 | 02:46 AM
patrickwong's Avatar
they probably put something in your car that caused it to have an allergic reaction!
Old May 23, 2006 | 02:51 AM
diablo1356's Avatar
wow thanks for the help..wong
Old May 23, 2006 | 03:50 AM
99atlantic's Avatar
400rpm is way too low
800rpm is way too high
in any case, they ****ed something up. If they were "cleaning the intake" (which sounds like they just raped you for $$$$) I'd wager something to do witht he MAF.
Old May 23, 2006 | 07:23 AM
g35rcr's Avatar
did they mess with the throttle body at all? might have to do the relearn procedure
Old May 23, 2006 | 02:57 PM
diablo1356's Avatar
thanks for the help guys...i did the whole relearn procedure (throttle open and closed and idle air volume)...and i think everything is fine now...i found out from another post that when you clean the throttle body it usually throws a code stating "high rpm"...and thats exactly what i was experiencing...but i did all the resets and stuff and its idling at around 650...which im assuming is correct??..anyways thanks!
Old May 23, 2006 | 04:13 PM
99atlantic's Avatar
yea, that's a normal idle. glad everything is workign fine for you
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
