Tire Balancing and my vibrating steering wheel (Comments are welcome, thx)
Old Jun 6, 2006 | 05:58 AM
ensheep's Avatar
Thank for all the great comments and sorry for late reply:
I have driven my car again, bringing up to over 80mph. I do feel some vibration, but the vibration feels like what my steering wheel vibrates when I start my car at idle state, only stronger.
Firestone probably didn't do a good job on balancing, so I will redo it at my 30k maintenance. However, the second tire balancing is already much better than the first one. I might also over react. I will see when the 3rd balancing is done at my 30k maintenance (currenty at 29000+). I will keep you updated!
Also, how does one determine whether the tires are defects or not?
Thanks! Good Day =)
Old Jun 6, 2006 | 06:53 AM
FAST1's Avatar
Originally Posted by antdiesel3
Alignment does NOT cause vibration. Warped rotors would most likely cause a vibration during braking.
Vibration at a certain speed usually is a tire being out of balance or out of round. Even new tires can have defects causing an out of round condition. Vibration can also be caused by a bent or out or round wheel.
It seems like he started experiencing the virbration after he had new tires installed. I would have to point to a defective tire as the culprit.
You beat me to the punch .A common misconception is that a bad allignment causes a vibration. I suppose if you drove with badly alligned wheels for a long enough time, the tires would have such uneven wear that it may cause a vibration.
In 99% of the cases steering wheel vibration is caused by improperly balanced wheels, bent wheel(s), improperly inflated tires or defective tire(s). The only other thing that can cause a vibration is a flat spot on the tires. Sometimes when a car has been in the same spot for a really long time, like some used cars on Dealers lots, a flat spot will develop which temporaily causes a vibration. After the tires are driven for a while, the flat spot will disappear.
Maybe you are lucky and it's simply a matter of improperly inflated tires. Carefully check the air pressure of each of your cold tires to ensure that they are in spec.
Old Aug 4, 2006 | 02:46 PM
Lucino's Avatar
what do you do with a tire that is out of round? can you shave it?
Also, I just got a flat tire and the shop just told there are bubbles coming out of it and therefore I need to get a new tire for the front, my tires only have 15K miles and i don't want to spend $250 on a tire just yet, I want to take my rim to get a second opinion, what do you guys think?
Old Aug 4, 2006 | 02:49 PM
RBull's Avatar
Rated M
You caught all the issues.
Old Aug 4, 2006 | 02:51 PM
RBull's Avatar
Rated M
Tires that are out of round are defective. Replace it or live with it.
If the bubbles are from a puncture you can have a patch put on it. On a speed rated tire I believe this eliminates any high speed rating because the tire is compromised.
Old Aug 4, 2006 | 03:00 PM
Lucino's Avatar
it was replaced this year (my wife's car) can I go back to the shop ask for a replacement?
Old Aug 4, 2006 | 03:32 PM
Gangreen350's Avatar
Why don't you try toyo T1R tires they are a lot smoother.
Old Aug 4, 2006 | 04:04 PM
runningonmt's Avatar
For an excellent explanation of the many things that can cause wheels to vibrate, check this out:
http://www.discounttiredirect.com/di...oBalancing.jsp
jsimonk
Dec 22, 2023 03:49 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
