faster downshift in manual shift mode??? - 5AT
Old May 29, 2006 | 05:54 PM
digglerg35's Avatar
03 coupe 5AT...
1) what kind of mod will allow me to DOWNSHIFT faster in manual shift mode? (valve body only helps for upshift)
2) is there a way to skip a gear to downshift 2 gears?
i want to downshift 2 gears quickly in mm, but it takes forever!! it has to go in sequence and takes it's sweet time doing so. has anyone figured out a way to improve this?? thanks
it will skip a gear if it's in auto mode, but i don't like this... timing is unpredictable.
Old May 29, 2006 | 06:17 PM
Gooz1's Avatar
Gordee's grounding gear will help.
Old May 29, 2006 | 06:40 PM
PeteNJ's Avatar
Originally Posted by digglerg35
03 coupe 5AT...
I have a solution. GET A STANDARD TRANSMISSION.
Manumatic is only good for pretending.
Old May 29, 2006 | 06:42 PM
stpdevil's Avatar
Your mm should downshift 2 gears at once... just hit it 2 times fast. I can get mine to go 5-3, 4-2, and 3-1 without any trouble.
Old May 29, 2006 | 06:45 PM
99atlantic's Avatar
same here - it requires a quick double-tap on the shifter.
Old May 29, 2006 | 10:51 PM
digglerg35's Avatar
i can't believe this!!!! i feel retarded and embarassed, but at the same time, i'm excited that it works! (2 clicks - faster than i've ever tried)
i'm usually in auto when i'm cruising and then need a 2 gear downshift, so i have to slide it right for 4th and then down for 3rd. i haven't tried doing this really fast, so maybe it works this way too... i'll figure that out in the morning. thanks for the quick reply guys.
wow!!!!! i feel ripped off that i didn't figure this out a long time ago. moderators may want to delete this thread to save space... i wonder how many drivers don't know this. just me?
Old May 30, 2006 | 02:04 AM
99atlantic's Avatar
yep ^_^
Old May 30, 2006 | 02:26 AM
GLuXuRy's Avatar
Hah... i didnt know that either.. gonna try it tomorrow
Old May 30, 2006 | 02:43 AM
ac1's Avatar
ac1
Shifting over to MM and pushing down quickly into 3rd is a very fast shift. Faster than if I were in 5th and quicly tap twice down to 3rd. So I rather cruise in D and shift that way to 3rd, the only thing I am worried about is the constant moving in and out of MM if any part of the shifter will wear down.
Old May 30, 2006 | 03:12 AM
truplay8's Avatar
THE BATMOBILE
didnt even know
Old May 30, 2006 | 03:13 AM
GLuXuRy's Avatar
is it for all 5AT years?
Old May 30, 2006 | 03:44 AM
cutiewolf's Avatar
does any one have any experiance when u downshift from 3rd to 2nd/1st it will have a BIG CLICK ENGINE SOUND as ur car pulls back / or slow down?
Old May 30, 2006 | 05:40 AM
dkim-'s Avatar
^simple.. when u want to redline n ruin the engine 8D
Old May 30, 2006 | 08:13 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
The other thing that improves the smoothness of down shifting is,
DON'T lift off the throttle until after the shift completes.
(especially in pre '05 w/o rev matching logic)
