Is there a way to check throttle position by computer?
Old May 30, 2006 | 10:11 AM
flnsx's Avatar
How can I find out if my car is giving 100% open throttle when I have the accelerator to the floor?
Is there a Vag-com type of thing I can plug in to see the A/F's and throttle percentages?
Old May 30, 2006 | 10:42 AM
HansMoleman's Avatar
yes.. but it'll read less than 100%.
Old May 30, 2006 | 10:57 AM
flnsx's Avatar
Can you explain why? That doesn’t sound good.
Why such a cryptic response?
Old May 30, 2006 | 11:24 AM
when you hook up a data logger it'll either give you a voltage or a conversion from the read voltage to an approximate Throttle postion.
the voltage say 0 - 5 V when at WOT is usually high 4 volts.. which reads from 92 - 97%.
if you are worried that the TB bttterfly isn't opening all the way you should verify this visually and not through electronics.
Old May 30, 2006 | 11:27 AM
g35rcr's Avatar
thats how they designed the throttle to work...you can rid this by getting an aftermarket reprogram
Old May 30, 2006 | 01:36 PM
SDG's Avatar
SDG
I JUST got the L-Spec flash from Technosquare last week. They change WOT to 100% instead of stock 80%. They up your rev limiter by 500 rpm also. Oh and they remove the factory set speed limit (145mph, this was really slowing me down )
http://www.technosquareinc.com/limited.htm
Old May 30, 2006 | 02:03 PM
99atlantic's Avatar
because after about 5000RPM at WOT the throttle body starts to close to like 80% of so to "encourage" you to shift. Totally gay.
Old May 30, 2006 | 02:19 PM
Thottle-by-Wire at it's finest.
Old Jun 1, 2006 | 02:12 PM
flnsx's Avatar
you try this reset?
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
Operation Procedures
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
with M/T, fully depress clutch, and hold in
5. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Jun 1, 2006 | 10:01 PM
Amarao's Avatar
Would be nice to just throw a wired throttle body on there, but I imagine that this would throw a SES. Might as well get the reflash, remove speed limiter, raise redline and fix throttle all in one shot.
Old Jun 2, 2006 | 12:30 AM
mal_TX's Avatar
6mt?
Does this apply to the 6mt? I'm guessing it does not, because if anything my car makes a lot more power above 5500rpm. Also, the 6mt already comes w/ a 7100rpm redline, and I doubt I need it moved up by another 500rpm to 7600rpm. Plus, I see pics of people exceeding 145mph in their 6mt's, so I wonder if there is even a speed limiter on it.
Anyone with a 6mt have evidence of a performance improvement (dyno, 1/4 mile times, etc) by doing a drive-by-wire remap?
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
