Help! Help! Help!
Old May 31, 2006 | 11:26 AM
Soju's Avatar
Help! Help! Help!
I debadged my car the end of last year, but left my infiniti logo on (mt fuji). I recently took of the infiniti logo as well in the rear/trunk. It seems that there is a shadow of the infiniti logo on my trunk. Any suggestions on how to remove that? Thanks!~
Old May 31, 2006 | 11:31 AM
arjunz's Avatar
have patience .. time will take care of it ... did you wax the area after debadging it?
Old May 31, 2006 | 01:01 PM
g35rcr's Avatar
you can try polishing or using a good cleaning wax
Old May 31, 2006 | 01:07 PM
johnbigbootie's Avatar
I had the EXACT same experience, I can still see a faint shadow of the "INFINITI" and "G35" lettering on my DG coupe deck lid. Time does help, it has gotten better over the last 2 weeks. But it's still not "perfect". I have polished with Scratch-X and waxed the whole area 3 times but it's still there (barely). I plan on going over the area one more time with Goo Gone, as I suspect there's still a thin layer of adhesive there, then re-waxing one more time.
Don't know if that helps you at all but at least you know you're not alone...
Old May 31, 2006 | 01:09 PM
mwarsh1's Avatar
all you need is a wheel, and some compound go to any body shop, they will help you.
Old May 31, 2006 | 01:49 PM
izmir41500's Avatar
G35driver Addict
the paint around it has faded from the sun so you could get it repainted, but waiting will make some difference but it will never match perfectly. the above solutions may help.
Old May 31, 2006 | 02:15 PM
truplay8's Avatar
THE BATMOBILE
it will fade eventually
Old May 31, 2006 | 02:18 PM
LjN_728's Avatar
It's God punishing you for debadging your car. jk
Old May 31, 2006 | 02:24 PM
Soju's Avatar
LOL!
Old May 31, 2006 | 02:26 PM
Soju's Avatar
Thanks guys.....I think I'll be doing some waxing this weekend.
Soju's Avatar
Wheel????
This forum requires that you wait 30 seconds between posts. Please try again in 9 seconds.
Old May 31, 2006 | 05:30 PM
Blackbird V35's Avatar
buffing wheel or pad
Old May 31, 2006 | 05:43 PM
LightsOutG35's Avatar
waxing and buffing will take care of the job.
Old May 31, 2006 | 10:48 PM
Soju's Avatar
Koo....koo..
Old Jun 1, 2006 | 01:43 AM
dosa's Avatar
When I debadged my car I scratched up the area a little bit, so when I was done taking all the adhesive off I saw an outline of the lettering.
I had 3M Rubbing Compound and used that to go over all the scratches. After a few coats the scratches were gone and so was the hazy shadow of where the letters used to be.
3M's rubbing compound works wonders on light surface scratches
