Pre-ignition?
Old Jun 8, 2006 | 12:40 PM
Lance's Avatar
I run Chevron 94 here in Vancouver BC and no sign of pre-ignition.
Old Jun 9, 2006 | 07:24 AM
alderran's Avatar
Originally Posted by timzcat
I am thinking with Sunoco 94 in the car it will be fine. I always ran this same gas stations gas in my Evo and never had a problem.
I'm assuming that you mean 94 octane. So I went to Sunoco this morning to fill up and there is no Sunoco 94. They had 91 and 93. I filled up with 93. I'm going to try it for a while and see if it gets rid of the knocking. I was filling up at Exxon and sometimes Shell.
Old Jul 31, 2006 | 08:02 AM
alderran's Avatar
Just wondering has anyone mentioned this problem to their dealer and had it successfully fixed? I took a look but don't see a TSB on it yet.
Old Jul 31, 2006 | 10:15 AM
trey.hutcheson's Avatar
When I put on my catch-can, it helped reduce the amount of *audible* knock, but didn't completely do away with it.
Old Aug 1, 2006 | 12:22 AM
timzcat's Avatar
You are correct, I didn't realize they were down to 93 now.
After getting the initial tank of gas out I have not really heard any detonation.
I believe they put cheap gas in at the dealer to save a buck.
It's going to be 100+ temperature here tomorrow so I will take a good listen.
Old Aug 1, 2006 | 01:04 AM
avs007's Avatar
Originally Posted by Msedanman
and also affects your gas mileage too.
Originally Posted by Echephron
think what you want... but, *any* detonation damages the engine... it's an uneven burn across the cylinder head pre-ignition... the heat generated can burn a hole in the piston even if there is only one instance of it...no repetition necessary...
Did something change? I remember in the owners manuals of my older cars, it said that light/occasional pinging was not detrimental, and said that light/occasional pinging actually yielded slightly improved fuel economy. Though it did say prolonged pinging can cause severe engine damage....
Maybe manufactureres were just full of themselves back in the 80's early 90's.
I'm glad my G isn't pinging at all.. (knocking on wood)
Old Sep 24, 2006 | 02:43 AM
bythabay's Avatar
so has anyone tried one step colder plugs? maybe copper plugs?
madmaxx72
Apr 7, 2012 06:15 PM
NFSP G35
45
Jun 14, 2011 02:40 AM
Breetie
Jun 6, 2008 09:35 AM
CPV356MT
Northern California
22
Feb 27, 2006 05:11 PM
