rattling issues and stink a/c
Old Jun 16, 2006 | 06:08 PM
gspothawaii's Avatar
so i keep taking my car back to the dealer for these problems. firstly, the sterring console / column has an incessant rattling. they cant seem to ,locate it, and i keep taking it back without much luck.
secondly, my a/c stinks for a few minutes whenever i turn it on. smeels like mold / funky midlew. i took it back, and for a day or two it smelled great. now its back to stinky again.
anyone have luck with either of these issues in fixing them?
otherwise, im loving the ride, just these are both annoying the hell out of me...
Old Jun 16, 2006 | 08:16 PM
TURBOTOM's Avatar
a.k.a kleicoupe
i have the same problems you do!!!
did they replace it with a charcoal filter?
Old Jun 17, 2006 | 01:29 AM
jonnylaw's Avatar
Make sure to turn off the ac a couple of minutes before you turn off your car. This should help prevent that mildew smell I believe b/c this will mimize condensation that would stick around if you have it on right before you turn off your car.
Old Jun 17, 2006 | 06:22 AM
Polishthrust's Avatar
Yea, i usually turn off the AC as im turning off the car, I used to get that smell when i turned the car on with AC already on.
Old Jun 17, 2006 | 09:51 PM
Sun35's Avatar
I had a really bad rattle from my steer column too. My dealership ended up filling the entire column with foam... no more rattle.
I've heard if you use the econ feature on the AC exclusively it can lead to mold growing in your vents due to the moisture, not sure if that is entirely accurate or not or if you are using the econ feature a lot. Just passing it along
Old Jun 18, 2006 | 02:01 AM
gizsf's Avatar
Charcoal filter took care of that stench in mine. You can pick 'em up pretty cheap now too.
Old Jun 18, 2006 | 02:49 AM
Fassster10's Avatar
I have the same thing and i am taking my G to the dealer to get a bunch of things corrected such as the rattling in the back, messed up button for the heated seats are not lighing up, transmission and coolant change, and the fuel line recall...should i change the cabin filter for a charcoal filter and where can i get it since i wanna do it myself and dont want infiniti to charge me 70 bucks to install it...
champppy
Mar 31, 2020 12:25 PM
baker2795
Sep 2, 2015 06:00 PM
Frostbite91
Aug 20, 2015 07:20 PM
kinetek
Aug 3, 2015 04:25 PM
