Here is my 1st oil report on second oil change.05'6mt.
oil is oem fill(valvoline synblend)oem filter w/ 3465k
car had 5607k.
whatcha guys think?
sorry about report did not come out like i wanted.had trouble uploading actual report.
lube time 3465k / unit time 5607k /date sample 6/13/2006 severity 1.
grade- sae 5w-30/lube type-valvoline synblend.
lube add-0.5qt. filter-oem nissan
wear metals contaminant metals multi-source metals
fe cr ni al cu pb sn cd ag ti v sil na k mo sb mn li b
15 0 0 2 43 2 1 0 0 0 0 29 5 1 24 8 1 0 18
test data
additive metals fuel soot water vis100c cs tbn
mg ca ba p zn 0.50 0.00 0.00 9.20 4.81
comments: data flagged for observation only;abrasives(silicon/dirt)are at a minor level;copper is at a minor level;bushing/thrust metal and/or most of the copper may be from lube cooler(as applicable);viscosity is slightly low;please provide unit manufacturer/model in order to compare data to proper standars for this unit;lubricant change acknowledged.
my comments:did provide lab w/ manf/model,they addmitted to missing.
so i dont really think silicon/copper is at a minor level for this engine/mileage????
car had 5607k.
whatcha guys think?
test data
where did u get your analysys done? I would say that not a bad composition and pretty much avaerage from what I have seen. The next few will be more telling.
