Do '04s Have More Problems?
Old Jun 27, 2006 | 05:41 PM
gsg's Avatar
gsg
No offense to anyone......but the '03's and 04's are the same car; so don't fool yourselves. If I remember correctly the only change on the '04's was adding a tire pressure light (which itself is sometimes problematic!).
If you read this forum thoroughly, I think you would find very little difference in the reported issues between '03's and '04's. Apparently some of the issues are not yet resolved by '06!!!
Old Jun 27, 2006 | 06:51 PM
silver g's Avatar
I have an 03 6MT with 47,000+ miles and I have had very good luck with mine. The only major problem I had was the clicking in the rear axel, but the dealer fixed it free of charge.
Old Jun 28, 2006 | 12:13 AM
space108th's Avatar
i have the same question as many others, how do u know if its 04 or 04.5 and does the 04.5 not have the brembo's? i bought mine used and im not sure if its the 04 or 04.5, if anyone knows how to really find that out plz let me know, thanx
Old Jun 28, 2006 | 12:26 AM
dp_PRIME's Avatar
I have an '03....no real significant problems at all. Only had to go to dealer once and that's for a slight problem with windows failing to work, but that's settled.
Old Jun 28, 2006 | 09:30 AM
gspotter's Avatar
All '04 6MT's have Brembos
Old Jun 28, 2006 | 09:43 AM
TheKnite's Avatar
Common sense tells me '04s have production date from January to June, and '04.5s should be July to December of 2004. I think you can find a sticker with the production date when you open your driver's door. I believe mine was born in March of 2004. .
Old Jun 28, 2006 | 09:57 AM
bocatrip's Avatar
Not quite correct. I have the first of the 04's and the production date is July 2003.
Old Jun 28, 2006 | 11:38 AM
EZZ's Avatar
EZZ
Yours is a 3.75.
The 04.5 had a revised tranny ecu too.
Old Jun 28, 2006 | 11:45 AM
b00stedjustin's Avatar
No issues with my 04 and it is from the first batch 07/03 production date. Just the normal stuff, replaced driver window motor, TSB for drift to right, replaced pads at 12,000 miles under warranty. I think (no offense to 03 owners) if you stay away from the first year you should be ok. Of Course the later models 05 and 06 have gotten just about everything ironed out. Now let's see what happens with the new and improved 07 sedan!
Yes and no dude. They have changed quite a few things on the new 07 so there may be as many problems due to the version that you see on brand new cars.
Old Jun 28, 2006 | 11:49 AM
SilverII's Avatar
04.5 = VIN that ends with ......800000 or greater
Old Jun 28, 2006 | 01:45 PM
Beowulf's Avatar
I have a 2003.5 and I had the same stupid problems everyone seems to complain about over and over every new year (even though 2006 model years.) The 2004 is pretty much exactly the same as the 2003.5; 2004 just has a flat-tire sensor.
Old Jun 28, 2006 | 02:30 PM
SilverII's Avatar
2004.5 is special..... cause it is ULEV. I think all others is just LEV
Old Jun 28, 2006 | 02:34 PM
bocatrip's Avatar
I was being sarcastic when I said new and improved. I know there will most probably be an entire new set of problems for the 07.
Old Jun 28, 2006 | 04:18 PM
ARTofDESIGN's Avatar
Originally Posted by glennp_1999
Main problem with mine was the squeeky brakes. After bringing the car to the dealer twice I finally replaced it with aftermarket and problem solve.....
what brakes you go with? and front and rear?
Old Jun 28, 2006 | 04:41 PM
  #30
space108th's Avatar
gspotter was saying that his 04.5 6MT has the brembo's... now does the 04.5 AT have it or the regular 04 AT have it?, jw
