parking stick placed on tint :(
Old Aug 11, 2006 | 10:21 AM
brianlitt's Avatar
Got an '05 yesterday, little things need fixing
I just got an '05 lease and it has a silly community college parking sticker placed ON the tint? Any ideas how I can get this off, or should I just have the back window retinted? If I get it retinted, how much will it cost, and should I do it at the dealership?
Oh, and my Track Button (on the radio) sticks a bit in the upward direction, any ideas on how I can fix that too?
Also, I know the infiniti has a 36,000 mile warranty on the brakes, where they will service them free of charge (so says the dealership). I hear a high pitch when I brake, but to be honest on all my cars I have heard that. Even right after I got my brake jobs. Any other ideas where the high pitch could be coming from?
Old Aug 11, 2006 | 10:41 AM
vjquan's Avatar
For the sticker, just peel it off. I'm assuming it's on the tint and not in-between the glass and tint. The 36K warranty on brakes were for '03-'04. '05's have redesigned brakes and fall under normal wear and tear.
Old Aug 11, 2006 | 10:46 AM
brianlitt's Avatar
Yeah, it's on the tint, not between the tint and glass. I was just worried that pulling it off would rip off the tint with it. Hopefully I can pull it off, sometimes these stickers are so sticky you can't do that.
Old Aug 11, 2006 | 10:54 AM
G-ThreeFizzle's Avatar
The sticking track button is a common problem...there's even a TSB for it...just take it to the dealership and they'll fix it. Make sure however that they do the TSB fixture, because the first time I took it in to get it fixed, they basically just greased up the button, and over time, it started sticking again. Hope this helps.
Old Aug 11, 2006 | 11:50 AM
brianlitt's Avatar
Sorry for my stupidity, but what is a TSB? Are you basically telling me that this is covered under warranty and I don't have to pay for it? I hope so!
Old Aug 11, 2006 | 11:58 AM
Calvin's Avatar
Overglorified Altima
i had stickers on my old tint and i took them off without any problems. you should be fine. just dont use a razor..or be very very careful if you do..
i just kept pickin at them and they eventually came off..
Old Aug 11, 2006 | 11:59 AM
Calvin's Avatar
btw congrats and welcome to the forums
Old Aug 11, 2006 | 12:50 PM
G SEDAN's Avatar
sometimes the stickers are stuck on by static only, meaning, there is no adhesive...becareful using the razor blade, because if you angle it wrong, you can cut into the tint. seems like it'd be hard to use that on the back since the g35 rear window is kinda curved...i'd suggest using the good ol fingernail first and go from there.
Old Aug 11, 2006 | 01:00 PM
A TSB is a Technical Service Bulletin...yes this should be covered under warranty.
Old Aug 11, 2006 | 01:15 PM
abcquackyxyz's Avatar
once you pick it off if there are any sticky residue left on it use some goo gone..that oil will take off any stick residue.
Old Aug 11, 2006 | 01:30 PM
brianlitt's Avatar
I dug a bit and got the thing off. It was one of those times where once you get a lip of the sticker off, you can easily peel the whole thing off. I was just worried the tint would come with it, but that did not happen.
Thanks for the info about that TSB, I'll call the dealership and see if they want to take care of that
Old Aug 11, 2006 | 02:02 PM
savefatkids's Avatar
same thing happend to me just push the screen up with ur fingers and it shouldnt be sticking anymore its just that the glue under melts and the plastic screen slides down
Old Aug 11, 2006 | 05:28 PM
M4Gunner's Avatar
Goo Gone is your friend.
Old Aug 11, 2006 | 07:58 PM
sjc1789's Avatar
Florida G35 Club
nice job brian... good peel!
R350k5
Lights
Jan 12, 2016 09:22 AM
KallDay86
Jan 8, 2016 12:42 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
