I am getting my turbo installed in two days, and i wanted to know if i need to change my clutch and flywheel. Will my clutch slip? If say that i will be getting number around 360-400whp?
eventually you will need a new clutch i don't think our oem ones can with stand the etra torque. Mind you I don't have a turbo but seeing how crappy our clutch is.
You will be fine for a little while. My roommate has a SC Max on a stock clutch. It's been a year; his clutch is starting to slip.
It all depends on how hard you drive your car. If your constantly dumping ur clutch, eventually it will take its toll.
i guess i will use it until it gives. how much usually do clutches run for?
