wut lights are on when you turn on headlights?
Old Oct 12, 2003 | 09:48 PM
nyckid's Avatar
do all your lights go on in your headlights when you turn em on? which one stays on? is there a switch to turn on/off the foglights? and do they come with bi xenons? where are the high beams?
Old Oct 12, 2003 | 09:58 PM
ryoken's Avatar
Re: wut lights are on when you turn on headlights?
We don't have bi-xenons. The high beams are halogen. The fog lights are integrated with the high beams (same bulb, lower brightness) -- so turning on the high beams overrides the fog lights. Not a big deal... if you need fog lights, you don't need high beams (the bright light reflects off the fog and back to your eyes). If you need high beams, they'd wash out the fog lights anyway.
This is how it is on my sedan. I assume the coupe is the same.
Old Oct 12, 2003 | 10:41 PM
nyckid's Avatar
so when you turn on your lights completely, all the lights in your headlamps shine? even the orange turn signal lights?
Old Oct 12, 2003 | 11:47 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
Do you already have your coupe? If so, then just go outside and turn on your headlights.
If not, why ask the question. Are you shopping for parts?
6MT Coupe, DG/G, Prem
Old Oct 13, 2003 | 02:03 AM
ryoken's Avatar
No, the turn signals only blink when they're engaged.. otherwise they stay off. The parking lights include a clearance/marker light (a little wedge bulb that dimly lights up the high/low beam portion of the headlights) and the side marker light (which is separate from the headlight assembly).
NOTE: I have a sedan. They're mostly the same, though I know there's that funky vertical light on the side of the coupe headlight assembly.. not sure what that is.
Old Oct 13, 2003 | 07:47 PM
afr0puff's Avatar
Supa Dupa Moderator
On the coupe, the turn signals are on the moment you turn on the parking lights. They just glow at a higher intensity when you use the turn signal.
http://www.anythingbox.net
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
wonderizm
Sep 24, 2015 03:09 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
attarday
Jul 15, 2015 04:03 PM
