6th to 2nd shift, need a peace of mind regarding damage.
Old Aug 20, 2006 | 10:23 PM
logik05se's Avatar
Originally Posted by Jellysick
I'm completely on board here. The other thing that's strange is that I have not seen the rev limiter kick in yet. Whether that be revving or when upshifting right at about redline.
Oh well, either way - I appreciate all of the words of wisdom. Lesson learned!
i hit it like 3 times...its there...
Old Aug 20, 2006 | 10:32 PM
mistermojorizin's Avatar
you didn't rev match? i revmatch from 6th to 2nd all the time and the car is fine. but if you didn't revmatch (you should revmatch even from 6th to 4th) then you might have some problems with your flux capacitator. that might have been the jerk that you felt. take it to your dealer have em check it out just in case.
Old Aug 20, 2006 | 10:42 PM
AgentAero04's Avatar
what? are you all girls here? Red line the beast at will. You are using synthetic oil and premium fuel,right?These engine's can easily take 6500 RPM,and pull into your driveway like a limo.These's engines are simply dying to go full out.
Old Aug 21, 2006 | 08:02 AM
Jellysick's Avatar
Premuim Fuel and syn. Oil for sure.
And I did rev match! Rev-matched for a 6th to 4th shift!!!
Old Aug 21, 2006 | 10:21 AM
Imadriver's Avatar
How fast were you going at the time? I'm still in my break-in period so I don't know the answer to this, but I'm assuming 2nd gear is good up until about 65MPH?? As long as you were under that, I wouldn't expect any damage occuring from what you described.
If you were going significantly faster than that, consider yourself lucky!
Old Aug 21, 2006 | 12:25 PM
Jellysick's Avatar
Actually I was slowing down. I was probably going between 60-65mph - maybe lower.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
