Info needed Coupe 17" winter tires
Old Aug 22, 2006 | 12:10 AM
smahara's Avatar
To those of you that run a 19" summer on your coupe what winter tire setup do you use? If you use a 17" what sizes do you use? Thanks
Old Aug 22, 2006 | 08:37 AM
monkeyboylawyer's Avatar
Do a Search for this. I have asked the same type of question in the past.
Old Aug 22, 2006 | 10:06 AM
mwarsh1's Avatar
im selling mint codition winter setup, if anyone is interested.
Old Aug 22, 2006 | 01:33 PM
gbest03's Avatar
Same here, I have a set of OEM coupe 17's with LM22 blizzacks available.
Old Aug 22, 2006 | 03:35 PM
smahara's Avatar
what tire sizes are the blizzacks?
Old Aug 22, 2006 | 03:47 PM
da mayor's Avatar
tirerack.com is the best way they ship it right to you...
Old Aug 22, 2006 | 04:00 PM
gbest03's Avatar
I'll Have to check when I get home, they are the recommended size from Tire Rack.
Old Aug 22, 2006 | 04:03 PM
GR8TG35's Avatar
The tire rack is a good source for your winter set up needs.
I believe my entire set up w/shipping and all mounting hardware came to less than $1,450.00.
I went with Dunlop Winter Sport M3. I went with 225/55/17's all the way around and put them on ASA KA3 rims,( rims No Longer Available)
Although Tire Rack recommends staying with a front to rear stagger, I went with the same size .
I had no problem with VDC/ABS systems, and it allows me to rotate the tires front to rear each season.
Old Aug 22, 2006 | 04:11 PM
Gbest03 - I just sent you a PM on this. thanks
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
NemesisGee
Aug 11, 2015 07:10 PM
Kal Hamm
Jul 24, 2015 08:55 AM
vstypicals
Jul 20, 2015 10:55 PM
papo020
Jul 17, 2015 10:30 PM
