Server Engine Soon light came on
Old Sep 9, 2006 | 07:18 PM
G35MC's Avatar
I had an oil change today at a local autoshop. Afterward, my "Service Engine Soon" light came on.
I checked the gas cap, it's closed tightly. Doesn anyone know a way to reset the light or should I try the dealership? Thanks.
Old Sep 9, 2006 | 07:49 PM
98intrigue's Avatar
Go to a Discount Auto or Autozone and they can delete the cel for you.
Old Nov 12, 2006 | 10:34 PM
viks14's Avatar
Same thing happened with me. Next day after I changed my Oil and air filter, the service engine light came on.
What did U do???
Someone plz advise.
Thanks in advance.
Old Nov 13, 2006 | 02:18 AM
bobshuai's Avatar
once dealer told me that when the rotors going low, check engine light will be on for few days.
Old Nov 13, 2006 | 07:18 AM
runningonmt's Avatar
It's possible that the place where you got the car serviced may have damaged or disconnected the wire leading to one of the oxygen sensors when your car was up on the lift. Or, if they replaced (or even just checked) your air filter, they may have unplugged the MAF sensor wiring harness. You can get the SES light reset, but unless it was caused by a transient problem it'll come right back on again. Whatever the reason, the important thing is to find out why it came on in the first place so that the root problem can be corrected.
Old Nov 13, 2006 | 10:51 AM
G35MC's Avatar
It's fiixed by the dealership. Throttle part needed to be replaced.
Old Nov 13, 2006 | 07:37 PM
dmhaxis's Avatar
Take it into the dealer to have them run diagnostics.
Old Nov 14, 2006 | 01:54 PM
Pro-Skyline03's Avatar
mines just came on last night, but since my mileage reads 39,500 and my next oil change is due on 40,200 i figured it was that, but now reading you guys problems im doubting, ill just take it str8 to the dealer man, dont take it to no autozone, even less if your car still under warranty
Old Nov 14, 2006 | 02:01 PM
i just called infiniti, they said it could be you need new brakes, i actually do need new brakes so im taking it in tomorrow morning to get my brakes done, if the light shuts off ill let you know.........
Old Nov 14, 2006 | 02:09 PM
filanj's Avatar
I would highly suggest buying your brakes online, you can get a whole set for under $160 for oem brembo pads.. your dealer will charge you like $600 or more depending on how majorly they are b@stards
Ednica87
Sep 5, 2015 02:59 AM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
