got a new 06 6mt, messed up with launch, burnt clutch?, sever smell, sqeeking, HELP
Old Sep 27, 2006 | 12:36 AM
ebuy929's Avatar
Exclamation got a new 06 6mt, messed up with launch, burnt clutch?, sever smell, sqeeking, HELP
hey guys,
i know alot of people posted about this but i need some direct help because im a paranoid fukc.
i just finished breaking in my car, 1000miles, and i wanted to finaly have fun, so:
i launched my car today in first. for some reason (common prob) my clutch got stuck when i full took my foot off it. Not noticing that my clutch wasnt disengaged, i was flooring the gas for 10 seconds.
i realized i was burning the clutch, so i pulled over and shut off my car.
a sever burning of oil smell filled my cabin and the outside of my car.
i drove the car home and it smelt up the whole block, even my neighbors complained. an hour later i took the car around and the smell came back when the car was idleing, it feels that my clutch is now much smoother and my friction point altered. (is this all in my head)
i will see in the morning if the smell is gone but i am extremly worryed, i know i burnt some life off my clutch, but how do i know as to how much, how can i check my clutch's remaining life.
also i noticed that now when i coast around 10mph i heare a squeeking rubing noise coming from my rear pasenger side axle or wheel (not clicking).. wat the hell is this coming from?
Old Sep 27, 2006 | 12:40 AM
Skaterbasist's Avatar
Retired SuperMod
If you only have 1000 miles on it... it shouldnt be that damaged from your mistake. But then again flooring it for 10 seconds while its engaged is a b!tch for the clutch.
Try this:
Go around 5-10 mph, shift to 5th, and floor it. If it engages then your fine. But if your rev meter goes crazy and doesnt lock, then your screwed.
Old Sep 27, 2006 | 12:52 AM
ebuy929's Avatar
thanx ill try tha tin the morning, how about the squeeking?
Old Sep 27, 2006 | 04:15 AM
Trezi13's Avatar
is it just a slight squeak everytime you let the clutch out??
Old Sep 27, 2006 | 07:09 AM
chilibowl's Avatar
Wow....you definitely glazed the sh*t outta your clutch homie...
Old Sep 27, 2006 | 09:12 AM
ebuy929's Avatar
ya well i woke up this morning and there was no smell, it felt fine and i was on my way. as soon as i started driving aggresivly, the smell came back...
when i got on the hwy it seemed fine but as soon as i down shifted the car reeked.
it seems to drive fine, i put it into 5th gear at 15mph and the revs were stable just the car had no pick up at all.
this smell is killing me wat the hell is going on, what do i do
Old Sep 27, 2006 | 09:42 AM
chilibowl's Avatar
The smell is not going to quickly go away. You burned a good portion of your clutch and over time the stench will go away. Have no worries, clutches arent that expensive, its the labor that will get ya, so I guess in all, yeah they are a pretty penny. Next time be more careful, and realize what you are doing. It wasnt your fault that the clutch got stuck halfway (which isnt THAT uncommon among the forums) but you should know your car by now and should of known the clutch wasnt engaged completely. As of now, dont do hard launches for a while and 'break-in' the section that you glazed.
Old Sep 27, 2006 | 10:45 AM
chobble19's Avatar
ive beaten my clutch up a bit but i never got any smells or sqeaks, just gurgles and rattles. did u put ur foot back on the pedal after u realized it was stuck or did u let it "pop" into gear?
Old Sep 27, 2006 | 10:53 AM
ebuy929's Avatar
ya i hear a little squeek when i realease the clutch too.
so in order to get rid of that smell i should just drive it soft for the next few days?
Old Sep 27, 2006 | 11:14 AM
Trezi13's Avatar
Yea im not sure but i know i hear that squeak to every single time i release the clutch, i dont think its anything wrong because i've never ragged on my car much at all. So i wouldnt worry about it unless you have reason to believe otherwise.
Old Sep 27, 2006 | 05:00 PM
logik05se's Avatar
so just out of curiosity the way to fix a glazed clutch is to basicly drive it easy for a few days?
Old Sep 27, 2006 | 05:26 PM
Igor911's Avatar
The squeek your hearing is your rear axle. There is a TSB for that
Old Sep 27, 2006 | 08:07 PM
Trezi13's Avatar
Sorry im not farmiliar with the terms What exclay is a TSB?
Old Sep 27, 2006 | 08:13 PM
Hexxum001's Avatar
Don't stress too much bro. I get a slight burnt clutch smell just going up my driveway. I have to go up at an angle cuz of how low my G is so I have to kinda feather the clutch sometimes. If I don't do it just right, I get that slight burnt clutch smell. My 05 did the same thing too. That's just the G clutch for you.
Old Sep 27, 2006 | 09:16 PM
2006_G_coupe's Avatar
Youll get into the swing of things as you keep driving.No need to worry.!!
