Detailed info needed on coupe rear deck removal
Old Oct 22, 2003 | 03:27 PM
NYCG35's Avatar
G SQUAD
Anyone have any detailed info how a step by step how to remove the rear deck in the g35 coupe.....and I mean detailed...not just a "take out the back seat" kind of answer....Pics would be great...thanks in advance...
BTW: I did a search and came up with some Service manuel pics but that doesn't really show you much.....and I'm noticing this aint easiest car enthuse site to search either...
anyway...some help if anyone has info??
Lexus for my luxury and Infiniti G35 Coupe for my speed. I must say...Life is not always a B!TCH
Old Oct 22, 2003 | 03:57 PM
davey2003's Avatar
Re: Detailed info needed on coupe rear deck removal
I'm actually going to attempt to hack that rear deck apart. I will take as many pictures as i can and will try to post after this weekend.
Old Oct 22, 2003 | 05:42 PM
tig488's Avatar
#1---remove seat cushion by grabbing about a foot from the ends on both sides and pulling up like a *****^$&*. then fold seat back forward, remove the two nuts on the back of the seat on both sides then in the middle back, undo the cable that goes to the trunk release, then remove seat.
#2---remove each lower side panel by again pulling very hard, you also have to loosen the door sill plastic piece, the upper sides will probably come loose with it which is what you want. you also have to take off the seatbelt holder thingy on the side. this is kinda tough but much easier with the seats out. i did it both ways and believe me its easier. at the part right next to the back window it is hard to get back there but just pull.
#3---now when all that is out, you need to remove the snaps on the front of the deck that hold it to the sheet metal right behind the reat seat, i think there are 2, the rear deck just slides forward and up, once you get some room reach under it and unplug the rear brake light then keep pulling till all the clips are out, and voila its out.
2003 G35 Silver/Graphite 6MT Prem Cp
19" Gunmetal TE37s 275/30 Michelin Pilot Sports
kg/mm supersport springs
custom camber rods
injen CAI
Alpine/JL Audio/Stinger
double din, he-he-he
Old Oct 22, 2003 | 09:48 PM
NYCG35's Avatar
G SQUAD
lovely detail ...now that is a useful response...Thanks
Old Oct 22, 2003 | 09:49 PM
NYCG35's Avatar
G SQUAD
Step by step pics would be the greatest,.,..hope you can do them please post
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
vstypicals
Jul 20, 2015 10:55 PM
