Will not doing the 15000 mile maintenance check void my warranty?
Old Oct 2, 2006 | 04:05 PM
Atooraya's Avatar
i did the search, and couldn't find anything on it.
A lot of the stuff seems kind of pointless
Old Oct 2, 2006 | 04:14 PM
CrazyRuskie's Avatar
Just do the usual fluid changes yourself, they can't void the warranty unless they can PROVE that whatever you did/didn't do caused the problem...
Old Oct 2, 2006 | 04:18 PM
LjN_728's Avatar
No it won't void the warranty. I got the typical oil and filter change, bought and replace all the filters myself. Saved me $150+
Old Oct 2, 2006 | 04:32 PM
gto2050's Avatar
A lot of the time, you can ask the dealer to do what Infiniti requires and not what the dealership recommends. There is often a huge difference.
Old Oct 2, 2006 | 04:40 PM
jigahus's Avatar
omg this is like the question about the 30k mile change earlier this morning.
Old Oct 2, 2006 | 05:00 PM
LjN_728's Avatar
^ Yea but the difference between the 30k and 15k is that you have to do the 30k.
Old Oct 2, 2006 | 05:04 PM
Atooraya's Avatar
15,000 Mile Service most vehicles... $299.95
Change Engine Oil and Filter
Install BG Motor Oil Conditioner and Fuel System Cleaner
Rotate Tires, Inspect for Condition and Adjust Tire Pressure
Replace Engine Air Filter
Replace Pollen Filter(s) * Q45 Models Extra
Adjust Parking Brake Assembly
Inspect Drive Belts
Inspect Automatic Transmission or Transaxle Fluid
Inspect Manual Transaxle or Differential Gear Oil
Inspect Exhaust System, Axles and Suspension Parts
Inspect Drive Shaft Boots
Inspect Steering Gear Linkage
Lubricate All Locks, Latches, door Checks and Hinges
Check Operation of Lights, Horn and Windshield Wiper
Road Test, Wash and Vacuum Vehicle
30,000 Mile Service most vehicles... $479.95
Rotate, Balance and Inspect Tires; Adjust Tire Pressure
Inspect Brake Pads, Discs, Lines and Cables
Replace Pollen Filter(s) * Q45 Extra
Inspect Fuel LIne and EVAP Vapor Lines
Flush Cooling System
Inspect Autopmatic Transmission or Transaxle Fluid
Inspect Exhaust System and Drive Shaft Boots
Inspect Steering Gear Linkage, Axles and Suspension Parts
Lubricate all Locks, Latches,. Horn and Windshield Wiper
Additional Charge for:
*Replace Fuel Filter
8Replace Pollen Filter(s) *Q45 extra
Old Oct 2, 2006 | 05:56 PM
LjN_728's Avatar
Inspect Drive Belts
I don't believe they install the BG motor oil conditioner and fuel system cleaner, unless that's what it states in our manuals. You already know the oil and filter change costs $35-40. The engine filter costs $7.20 and the in-cabin costs $25.95 from here: http://www.mynismo.com/categories/?id=2274
Old Oct 2, 2006 | 06:33 PM
2006_G_coupe's Avatar
I dont think it will.!
chinee
Jun 10, 2024 07:48 PM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Jay 21
Aug 5, 2015 04:53 PM
newbdriver01
Jul 15, 2015 06:10 PM
