Plenum spacer & mpg
Old Oct 4, 2006 | 08:36 AM
jouvert00's Avatar
Plenum spacer & mpg
A couple of weeks ago I installed the aam spacer, definitely noticed the power increase but during daily driving I have noticed that my gas mileage has decreased significantly, this is without getting on the throttle (non spirited driving).
Anybody ever experience this with the plenum spacers?
Old Oct 4, 2006 | 09:31 AM
chilibowl's Avatar
Reset your ECU
Old Oct 4, 2006 | 10:10 AM
jouvert00's Avatar
Originally Posted by chilibowl
Reset your ECU
Is this procedure necessary after a mod install or will the ecu reset itself after drivetime??
Old Oct 4, 2006 | 11:59 AM
fortified's Avatar
I disconnected the battery, then after installing the spacer I turned on the ignition and held the brake pedal down for 30 seconds.
Then reconnected the battery. That should be sufficient for clearing the ECU.
It should 'learn' fairly quickly. I have not noticed any change in mpg except when I like to put my foot in it.. which is more now!
Make sure you don't disconnect the throttle body connection or move the plate. If you do, you need to run the procedures for calibrating those. Should be in your instructions.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
