DO it yourself (brake pad) change
Does anyone have information or website I can take a look? I want to replace with some hawk pads, the 2005 coupe got pretty crappy brake pad stock.
Do a quick search and you should find a few, I used a couple write ups from the forum and a couple I googled when I changed my own last year. Wasnt that bad, but I wouldnt recommend it unless you have a good jack and jack stands.
If you got brembos, then this DIY thread will work for you:
https://g35driver.com/forums/florida-g-club/92495-my-brembo-pad-replacement.html
Originally Posted by SilverII
remove wheel
remove caliper
remove old pad
insert new pad (with new shims)
reinstall caliper
reinstall wheel
not too difficult
remove caliper
remove old pad
reinstall caliper
reinstall wheel
not too difficult
Channel Locks work well, but you *can* buy a piston compressor.... they're a piece of cake to change, took me 15 minutes per axle and all I used was my crappy oem jack...
kinetek
Aug 3, 2015 04:25 PM
