Need Help!!
Old Oct 11, 2006 | 01:08 PM
bull3t's Avatar
Need Help!!
i posted this in the wheels and tires section but i got no replies...i need to know
if there are any negative effects from having this tire setup...235/40 18 in the
front and 245/45R18 in the rear...i think the speedometer is gonna be off but
any negative effects besides that??? i might get these tomorrow so any
feedback would be appreciated
Old Oct 11, 2006 | 01:11 PM
Nismo G's Avatar
You might have a couple problems with your VDC. It will cause it to turn on when you are barely cornering hard. I have stock 17s and im running a 45 sidewall and it should be 50. The speedo is off a little bit and also the VDC will activate at weird times.
Old Oct 11, 2006 | 01:15 PM
bull3t's Avatar
^^^my car does that sometimes with the oem set up...do you think itll make it worse with the new tires? anybody else got something to say?
Old Oct 11, 2006 | 03:30 PM
Nismo G's Avatar
i dont think its going to make a huge difference. It should be fine, if you plan on messing around a little i would just turn VDC off. I would like you to post pictures though of your rims with these tires on it though. I wanted to do the same thing and i wanted to see what it looks like.
Old Oct 11, 2006 | 08:25 PM
bull3t's Avatar
alright ill post pics tomorrow...hopefully my tire guy received them
Old Oct 11, 2006 | 11:03 PM
bull3t's Avatar
bump
Old Oct 12, 2006 | 04:56 PM
bull3t's Avatar
alright i was trippin...the height of the new tire is the same as the pilot sport...i
didnt realize that the second number is the percentage of the width...anyways i
got them....if you dont wanna spend around 300 per tire for the pilot sports than
i recommend these hankooks...i think they look better and its wider then the
stockers...also the treadwear is 60 better then the pilot sports...here's some
pics
Attached Thumbnails Need Help!!-new-ian-888-026.jpg   Need Help!!-new-ian-888-027.jpg
