Loose Cable... what is it?
Old Oct 14, 2006 | 07:00 PM
gmoney1227's Avatar
Hey Guys,
I was washing my G35 Coupe today and I noticed that underneath where the electrical wiring is located by the pedals, this cable was just dangling there. I've never noticed it before so I was hoping you guys can tell me what it is and if it's supposed to be connected, and if so to what? Thanks!
Old Oct 14, 2006 | 07:11 PM
Calvin's Avatar
Overglorified Altima
uhhm thats the speed cable. when you plug it back in youll get an extra 95whp. duh, i thought everyone knew that
lol im really really bored..i should be writing my paper but im not..anyway, i hope you find your answer!
Old Oct 14, 2006 | 08:02 PM
clifftrail's Avatar
Connects to the turbonator that you buy on ebay. Good for @ least 45rwhp!
Old Oct 14, 2006 | 10:29 PM
gmoney1227's Avatar
LOL... come on guys seriously!! Anyone know what that is?
Old Oct 15, 2006 | 11:51 AM
gmoney1227's Avatar
Really, no one is going to help me out with this? Come on, nobody is ever failed me here.... we all help each other, remember?
Old Oct 15, 2006 | 11:54 AM
chilibowl's Avatar
That's the Ipod hookup. Connect it to the bottom of your Ipod and you will gain an extra 10GB's of music power. Good luck !
Old Oct 15, 2006 | 12:06 PM
g35rcr's Avatar
thats an aux plug for an option not offered in the us
Old Oct 15, 2006 | 05:07 PM
gmoney1227's Avatar
Okay, I realize I'm fairly new to this forum, but is there any reason why all the answer are being ridiculous?
Old Oct 15, 2006 | 06:05 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by gmoney1227
Hey Guys,
I looked at that yesterday and couldn't come up with an answer.
Having thought about it again, tho, I'd have to say the receiving connector couldn't be far off. The pigtail isn't very long, so if you get in there and get behind the fuse door, you should be able to come up with it.
Even up above the clutch should be within reach of that, but certainly behind that fuse door, and even behind the fuse block which will have 2 mounting screws.
Bear in mind tho, that some connectors aren't used in our rides.....this all depends of options and different models, and sometimes means that there are leftover and unused connectors that can come loose and into view.
BTW, has anything stopped working? lights or functions? That may give you a hint as to where to look.
If all else fails, a quick visit to the dealer would be all you'd need for a definitive answer.
Best of luck, and when you do find out what it is, let us know too would you.
I'm sure everyone is wondering too....
Colin.
Old Oct 15, 2006 | 06:11 PM
Calvin's Avatar
and which option is that? (not meant to sound like a smart@$$ question, i really do want to know)
Old Oct 15, 2006 | 06:16 PM
stillen_i30's Avatar
whoa, very strange find. anyway, i'd agree with the other guy. when i did the clutch pedal height mod, i removed that fuse box door completely and saw a bunch of places back there where you snap in harnesses. it must have come out from back there somehow, from hitting a bump or something was loose to begin with.
basically, just look around in there for something open...it must have come loose from where in the vicinity since the wire is so short...pull the wire in all directions as far as it can go and this tells you all the possible places you should look within that circumference to look for open connectors. good luck
FAST1's Avatar
The first thing that I would do is to check to make certain that everything works. I suspect that the answer will be yes, and then it could be a wire for some option that you don't have. Without a wiring diagram, we will all be just guessing.
Old Oct 15, 2006 | 06:34 PM
Msedanman's Avatar
O.F. Administrator
Another thought: It's the connector that used on the foot operated emergency brake in auto equipped g's.
If that's the case, then it's just come loose from where it was tucked into amongst other wires.
Colin.
Old Oct 15, 2006 | 06:50 PM
partyman66's Avatar
I can't tell how many pins are no it... could be your ODBII hookup.
Check the FSM and see if that's where the ODBII plug is.
Old Oct 15, 2006 | 07:12 PM
MY2k6G35C's Avatar
That's where you plug your floppy disk drive for power.
