door lock broken?!?!
Old Oct 23, 2006 | 01:34 PM
oscottio's Avatar
i have a 04 coupe. i noticed that my door lock on the driver's side wasn't unlocking on the first press of the key fob. i would have to press it twice, sometimes it wouldn't unlock at all and i would have to go through the passenger side and manually unlock it. from playing around with it, it seems like whatever device that unlocks the door is weak. when i sit inside the car and press the lock/unlock button, i can see it barely moving..but the passenger door is flipping open and close. has anyone had this problem? i'm gonna make an appointment with the dealer this week.
Old Oct 23, 2006 | 01:38 PM
gqong's Avatar
i have the same problem on my passenger side. my car is out of warranty so i am going to try to replace teh door lockc assembly myself. if you are under warranty i would just get the dealer to fix it.
Old Oct 23, 2006 | 05:30 PM
BroDaJin's Avatar
it's probably a weak door lock actuator, if not try to lube all the linkage and door locks.
Old Oct 23, 2006 | 05:36 PM
oscottio's Avatar
i was thinking about it..but then i called and made an appointment at the stealership. it's still under warranty, and i gotta get my freaking auto window rollup fixed. now both my windows are rolling back down.
Old Oct 23, 2006 | 05:41 PM
silver g's Avatar
Yeah I had the same problem. Dealer fixed it for me for free.
Old Oct 25, 2006 | 09:12 PM
oscottio's Avatar
yup...dealer said it's the door actuator that's bad and it's a common problem. they ordered the part so i should have my car back tomorrow evening. they also replaced both door window motors. i had that auto rollup problem where it goes all the way up and then down about 2/3 the way. freaking annoying. passenger side did it twice in the past, driver's side first time. this is a sign that the motor is going out and that there's a short in it. anywayz..its freeeeeeee. i need to practice drifting in my loaner. =)
Old Oct 25, 2006 | 09:28 PM
nm3th's Avatar
^^^Haha... that's the perfect time to go drifting. Good luck with the repairs, Scott.
TPC!!!!!
G35-R
Nov 7, 2015 01:21 PM
itgogitrev
Sep 23, 2015 07:08 PM
TNRocker
Sep 21, 2015 08:36 AM
douglas555
Sep 10, 2015 04:48 PM
