i think i am retarded
Old Oct 30, 2006 | 08:20 PM
cchaorule's Avatar
okay i am about to paint my grill black.. but i am having trouble taking it out of my car.. can anyone tell me how to take out those bolts? thankss..
sorry for this retarded post
Old Oct 30, 2006 | 08:27 PM
Calvin's Avatar
Overglorified Altima
theres for clips on the top. just pop those off. then theres a few clips on the bottom. just pull the grille out.
oh and there are two clips (one on each side) that need to be turned 1/4 turn clockwise or counterclockwise before you can pull the grille off. im talking about the 2 square clips (1 on each side) which look like <->..you need to turn the 2 square clips so they look like [\]..just look around..itll be obvious once you see it
use a flat head to turn those clips
Old Oct 30, 2006 | 08:33 PM
AthensBlueG's Avatar
Brian
This thread will help you, it has pictures -Even a retard can figure it out with pictures! (j/k)
https://g35driver.com/forums/body-interior-exterior-lighting-diy/75211-diy-projector-retrofit.html
The thread is in regards to changing your headlights, but it still provides detailed instructions on how to remove the grill.
Good luck, and go slow.
Muski_G
Dec 1, 2023 11:11 AM
MeanGene
Forced Induction
Oct 15, 2004 10:24 PM
GurgenPB
Jul 15, 2004 05:36 PM
